its not sucking!!!
Old Jul 8, 2005 | 02:37 AM
Rimjay's Avatar
Default its not sucking!!!
when i got my inejn cold air intake fot the tc, when i accelerated i could hear the sound of air sucking in by the CAI, but recently ive noticed i cant hear it anymore..the sound has gotten a loud softer, meaning the air sucking noise has gotten very low...is this normal??
Old Jul 8, 2005 | 02:41 AM
retrodrive's Avatar
maybe you should blow some in.
Old Jul 8, 2005 | 05:08 AM
Harmonic_tC's Avatar
ill switch intakes with you
Old Jul 8, 2005 | 06:26 AM
Mizle's Avatar
ill take it off ur hands if its causing you too much trouble ;)
Old Jul 8, 2005 | 01:45 PM
cubaricantC's Avatar
it may be you've just become accustomed to the sound now, but to be on the safe side and to spare yourself any engine troubles, double check your connections. Make sure all the clamps are tight and check your filter to be sure nothing is obstructing the air flow. If it is dirty... clean it. If everything is tight and the filter is clean and free of debris, you should be ok just do a simple test, have a friend at the throttle and you by the filter, have a sheet of paper handy. Have your friend hit the gas and you put the paper by the filter, if it suks the paper to the filter your air flow is fine and your just adjusted to the sound of your intake. If its not getting any suction though I would do a thorough check up of the intake system from the TB to the filter to make sure everything is working properly.
Old Jul 8, 2005 | 02:06 PM
Rimjay's Avatar
ok thanks...but i just got the intake in about a month ago, is it possible theres a problem already with it? the only thing i do is just punch the gas once in a while from a starting point, could that be it?
Old Jul 8, 2005 | 02:34 PM
Lonely_Raven's Avatar
Try getting it more drunk, that always works for me when
I need more sucking...
Just look out for the spewing if it gags.
Old Jul 8, 2005 | 02:42 PM
melongunner's Avatar
fellatio from a cold air intake, now that's funny.
Old Jul 8, 2005 | 02:56 PM
cid_mcdp's Avatar
1. Open hood.
2. Start car.
3. Wait about ten seconds.
4. Roll down window.
5. Put head out window.
6. Stop car.
7. Listen for sucking sound present for about half a second after you kill the ignition.
Old Jul 8, 2005 | 10:57 PM
Greg2385's Avatar
Originally Posted by cid_mcdp
1. Open hood.
2. Start car.
6. Stop car.
Old Jul 8, 2005 | 11:04 PM
B1uEsC1uEs's Avatar
thats normal. my intake got quieter when jus tapping the gas but when u hit 2.5 to 3 rpm, it makes taht sexy noise. dont worry its supposed to be like that. its jus that ur car prolly jus got used to it.
Old Jul 8, 2005 | 11:07 PM
hahaitzskippy's Avatar
Default Re: its not sucking!!!
you are perfectly fine.
the intake shoud make a low tone to a loud roar if you floor it from low rpm to high rpm (respectively)
Old Jul 9, 2005 | 12:14 AM
Rimjay's Avatar
thx hahaitzskippy and b1uesc1ues
Old Jul 9, 2005 | 03:06 AM
retrodrive's Avatar
it is a piece of pipe
Old Jul 9, 2005 | 08:59 PM
87na's Avatar
there is probably no problem with it at all. even though it has only been about a month you may have gotten used to it by now. you may want to check all your connections and clamps to make sure there is no "leak." like most people have said, there is probably nothing wrong, good luck.
Old Jul 10, 2005 | 02:06 AM
Rimjay's Avatar
ok thanks
Old Jul 10, 2005 | 04:40 AM
Somnambulated's Avatar
Your ECU probably adjusted to having the intake there instead of the stock intake box.
That, or you're not punching your gas pedal just to hear your intake make that cool 'hiss' sound anymore.
Old Jul 11, 2005 | 01:05 AM
Diluvium's Avatar
ill trade you my Weapon-R Intake for the Injen.. i personally want a CAI.
yhwhdesign
Jun 11, 2021 03:34 PM
mudguy
Oct 22, 2015 04:31 PM
BlingSlade
Sep 5, 2015 08:52 AM
scionsux
Sep 2, 2015 05:30 AM
hampton1100
Jun 19, 2015 05:08 PM
