General Turbo Q's...
Old Jul 16, 2005 | 03:56 AM
mikek6789's Avatar
Default General Turbo Q's...
Hello,
I just had a few questions about turboing a tC..
1. Do you need special oil?
2. Should you let your car idle for 1min everytime after you drive before turning it off (i will do this manually, without a turbo timer, if you need to)?
3. Is there a point in having a BOV in an auto tC?
4. Lets say i just installed my turbo, ic, everything is ready, even the eManage i will use, and i put in the proper oil... Am I set to go, is it safe to rev the engine right after i finished the install? Looking at boost, afr, and egt guages, and maybe oil pressure?
5. I probably wont get an oil pressure guage (is that okay?) and am not going wideband for the afr guage, is that ok too?
Thanks!
mike
Old Jul 16, 2005 | 05:53 AM
VoLktc's Avatar
1. nothing special maybe just a higher viscosity.
2. no idea but retained boost in an engine and piping can never be good.
3. yes
4.id take it easy to be safe. it would be a sad day to blow your engine after getting F/I
5. no clue
Old Jul 16, 2005 | 06:30 AM
mikek6789's Avatar
3. yes
5. no clue
thanks, but for the BOV it wont release air between shifts will it? lol, unless i feel the shift coming and release the pedal and press it again
Old Jul 16, 2005 | 06:31 AM
mikek6789's Avatar
oh yea, and is it harder to drive with an turbo setup? with lag and such
Old Jul 16, 2005 | 07:02 AM
Joe_Dezod's Avatar
It's just as easy to drive, if not easier, but it'll only take a sec to spool up depending on which kit you buy. The BOV wont go off on an Auto until you let off the gas. Keep in mind its not for the sound, it's to relieve the charge pipe of a stressful (high high psi) amount of air that would normally riochet back at your turbo as soon as the throttle body closes.
Give the car a couple minutes to warm up when you start it if it hasne't been run for a while. It'll add to the life of your piston rings in the long run. Let it idle for a min or two after driving for a while to use the oil feed line to help cool the turbo off, increasing life. To properly setup a new turbo, disconnect your coils and crank the motor a few times. This will get oil into your turbo before it starts spinning. It's a quick trick that should help in the long run. Note, you only have to do this once. Once that's done, there's really no wait, get on it and have fun.
As for the Oil psi gauge, it's not completely neccessary but it does help. If it drops you know your oil feed to the turbo is leaking and can shut down the motor before you blow the turbo or seize the engine. The AFR is great, but once it's tuned, you should be ok. Just take it to the shop once in a while to make sure everything's running correctly.
Hope that helps.
Old Jul 16, 2005 | 07:25 AM
mikek6789's Avatar
Hope that helps.
ah thanks! that helps ALOT!
so looks like im buying: turbo kit, boost guage, afr guage, oil press guage, and egt guage...
$$$ haha, its ok, i have about 4k to blow :-P
Old Jul 16, 2005 | 07:45 AM
TurboMe's Avatar
yeah thats what auto GTI's do. Gas it up hard in low gear and release the gas. Sounds just like a BOV if not better. but when racing its pretty silent.
Old Jul 16, 2005 | 08:43 AM
Joe_Dezod's Avatar
Just a quick FYI, I'm sure you know, but depending on when you're planning to buy, our turbo kits should be available next month. Thanks.
Old Jul 16, 2005 | 04:30 PM
matty-tC's Avatar
Default Re: General Turbo Q's...
No, high quality synthetic works fine.
Yes. What this does is circulates the oil to cool the turbo down. It helps lengthen the life of your turbo.
Yes.
Stay out of boost until you're tuning it. Once you're done tuning it I would drive for 1k miles to break in the turbo.
It's ok not to have an oil gauge as long as you're confident you're keeping oil pressure.
And as long as you get the car tuned correctly, you won't need a AF gauge. The narrowband AF gauge's are just blinky lights anyways. They're not accurate enough to really rely on.
Old Jul 16, 2005 | 08:13 PM
mikek6789's Avatar
Yes.
but i leik teh blinkay lightars
Old Jul 16, 2005 | 08:16 PM
mikek6789's Avatar
Yes.
for tuning im just relying on dezods pre programmed emanage. is that ok?
Old Jul 16, 2005 | 08:54 PM
matty-tC's Avatar
they're tuning it "safe" which means a little richer than normal. you should be fine with that but you may want to have a single dyno pull to get your AFR on paper, and have a pretty little sheet of paper to post online
Old Jul 17, 2005 | 04:40 AM
mikek6789's Avatar
okay thanks
Old Jul 17, 2005 | 01:59 PM
Joe_Dezod's Avatar
Sounds good guys. Thanks for covering that Q matty...
Old Jul 17, 2005 | 09:40 PM
matty-tC's Avatar
no problem.
laforze
12
Feb 16, 2016 12:50 AM
tckid21
Jan 9, 2016 09:19 PM
Scionxa180
Sep 24, 2015 03:51 AM
brett561tc
Sep 15, 2015 06:33 AM
Mpwr
Jul 17, 2015 08:39 AM
