Sunroof Problems
Old Jul 18, 2005 | 03:41 PM
sONicRoK1's Avatar
Default Sunroof Problems
My sunroof has a mind of its own. Sometimes when i try to close it, it goes into that snag mode and brings my sunroof wide open when it should be closed. Does this sound familiar to anyone.
Old Jul 18, 2005 | 03:50 PM
DOWNSHIFT's Avatar
take it back to the stealership and have them look at it
Old Jul 18, 2005 | 03:51 PM
jaewon223's Avatar
that sucks
Old Jul 18, 2005 | 06:00 PM
SuperScionicSound's Avatar
Needs lubrication..........Heh heh, I said lubrication.......
Old Jul 18, 2005 | 06:29 PM
ssdm7683's Avatar
I haven't had any such problems, sorry to hear you're having problems w/ your roof.
Old Jul 23, 2005 | 04:12 AM
mfbenson's Avatar
Mine does it too. If I reach up and hold the front flap down with my left hand while closing the sunroof button with my right hand I can close it. Can only do that when stopped though, since I don't have three hands to keep one on the wheel...
Old Jul 23, 2005 | 06:18 AM
CharlieLed's Avatar
I notice that mine collects a lot of dirt up under the front panel. I try to keep it cleaned out just so that the dirt won't make it into the roof mechanism. Try a little spray cleaner followed by some white lithium grease (spray can) to get the rails freed up.
Old Jul 23, 2005 | 01:10 PM
Juggalo79's Avatar
my sunroof does the same thing, it started off doing it on really hot days now its more frequent.
Old Jul 23, 2005 | 01:33 PM
RockBlocker's Avatar
I dont have any issues and I leave in the heat, AZ!! But I also dont exactly open the sunroof when it is 116 out.
Sorry to hear about the problem.
Old Jul 23, 2005 | 05:59 PM
bsp_tC's Avatar
does anyone have the problem of one side of the sunroof not being flush with the rest of the roof?
Old Jul 26, 2005 | 10:41 PM
stl_tc_king's Avatar
for me neither side is flush and it makes a whistling sound at 30mph up.
Old Jul 26, 2005 | 10:43 PM
ack154's Avatar
Mine does the same thing occasionally. Seems to be when it's warmer out. Might just need some lube... hehe... lube.
Old Sep 5, 2005 | 07:25 AM
texas1emt's Avatar
Well, ack154, have you tried using ranch?
Old Sep 9, 2005 | 10:08 AM
mononeo's Avatar
Does anyone elses rattle when you go over bumps? I go to the University of Oregon, and because it is so crowded, and all of the roads on campus are one ways and one-lane, they can't ever repair them or it would mess up traffic really bad...thus, the roads are really bumpy. When I drive my car over the bumps the sunroof rattles (when it is open)...but if I close it like 2 inches, it rattles less. Should I be worried or is this normal?
Old Sep 9, 2005 | 11:01 AM
sciontc_mich's Avatar
if you have an 05 tC, then there is a service bulletin about adding thread locker to two bolts.. other than that.. some of use have found that the arms that raise the wind deflector is causing the noise.. some have added shims to those arms, others have just quieted it down with white lithium grease into the joint (where the arm meets the wind deflector)
normal? shouldn't be, but a lot of tc's have it..
Old Sep 16, 2006 | 03:35 AM
paultg's Avatar
Just thought I'd ad to this after hearing back from my dealer.
I have had my 2006 Scion tC for about 6 months now, have 10K miles on it and just brought it in to the dealer for service. I asked them to check the sun roof because:
1. A few times it has stopped closing (when hitting the front tracks for the air deflector) and reopened.
2.It seems to rattle alot when open.
Well, got the call today. I expected to hear "We cleaned the tracks, you are all set", but instead I got, "We have a new sunroof and front air deflector on order, we need the car for a few days". They said there is something wrong with the glass (warped or something).
So, I get a new sunroof.
Just a heads up. If you have these symptoms, definetly take it to the dealer before you clean the track yourself. There could be something else wrong.
Paul G.
Old Sep 16, 2006 | 03:48 AM
ApEx81's Avatar
Yup. Having the same problem. Gonna get it checke out this week. Will post my results. I work @ a Scion dealership, so hopefully they'll give me some info as to whether how frequent this is happening.
Old Sep 16, 2006 | 03:52 AM
paultg's Avatar
Cool,
Definetly post up. I didn't very good info about what was wrong (only talked to the service writer, don't really get to see/talk to the techs). I'd love to know what was up. I seriously thought they would clean things up and tighten something (all of which I was prepared to do myself, but figured, let them screw with it first).
I was shocked to hear new sun roof assembly.
Paul G.
Old Sep 16, 2006 | 07:48 PM
stephen6119's Avatar
hey, i had the same problem, i just took it back to the dealer and they fixed it for me.
Old Sep 16, 2006 | 09:19 PM
chazm's Avatar
Not to hack, but can anyone explain why the sunroof stops when you are closing it and then you have to let go of the button and push it again to close it all the way?
