Installed Camcon VVT-I controller
Old Jul 22, 2005 | 04:49 AM
OutCrnrU's Avatar
Default Installed Camcon VVT-I controller
I absolutely love it, i highly recommend it for every tC owner, whether you are already modded or not. any questions feel free to ask, im not sure who else has it installed if anyone.
later
Old Jul 22, 2005 | 04:59 AM
spray's Avatar
got any pics?
Old Jul 22, 2005 | 05:11 AM
datrickster24's Avatar
post more info like, what you can set it too, how much hp gains in what rpms.... etc, how is it helpful, how is it bad.
Old Jul 22, 2005 | 05:12 AM
HKSpeed's Avatar
what exactly does this do? does it work like a vtec controller for hondas? what rpm is does the variable valve timing on a stock tc kick in, and how low can u adjust it with this product? sorry for the numerous questions.
Old Jul 22, 2005 | 05:14 AM
smn's Avatar
smn
post pics please!!!!
Old Jul 22, 2005 | 06:03 AM
OutCrnrU's Avatar
pics and info tomorrow, sorry its late for me and i dont have the thinking capacity at this time to explain everything, haha.
ill give much more info and pics tomorrow
night all
Old Jul 22, 2005 | 07:24 AM
yellot00tr's Avatar
what mods have u done so far exactly? how much did it cost u to tune and what were the dyno numbers before and after install?
Old Jul 22, 2005 | 08:41 AM
mr_lore's Avatar
^^^ What he said.
Old Jul 22, 2005 | 11:19 AM
firesquare's Avatar
thsir is a pic in the xA xB power hungry. check the sponsored section and lastlookcustoms for more info on the cam-con.
Old Jul 22, 2005 | 11:36 AM
djct_watt's Avatar
Team Sushi
Yes, please. I've been critical of this thing since the beginning, and want to see how it does in the real world. If it's as good as you say, I may get one.
Old Jul 22, 2005 | 01:29 PM
matty-tC's Avatar
why is it better than the emanage?
Old Jul 22, 2005 | 01:42 PM
wOoOzZy's Avatar
I think they do different things. Does the emange do cam adjustments? If it does then I guess the camcon is just a lesser version of the emanage.
Old Jul 22, 2005 | 02:15 PM
TurboCustomz's Avatar
The emanage does not do cam adjustments. It does have the ability to adjust the overall timing however. It does fuel, timing, anti stall, ect ect and the new emanage black even has features such as top speed eliminator and rev limit eliminator for cars with a fuel cut limiter.
Charles
Old Jul 22, 2005 | 05:14 PM
matty-tC's Avatar
Emanage can adjust VTEC i'm not sure why it wouldn't adjust VVTi
Old Jul 22, 2005 | 05:24 PM
engifineer's Avatar
VVTi is a cam angle adjustment and is continuously adjusted. VTEC (at least the forms that I am familiar with) switches between one set of cam lobes and another, so it is more binary in nature. I have not used emanage so I cant say for sure, but it may not be set up for the continuously variable timing setup.
Old Jul 22, 2005 | 05:26 PM
engifineer's Avatar
Charles
I believe it adjusts overall ignition timing but not valve timing correct?
Old Jul 22, 2005 | 05:31 PM
Thrawn's Avatar
Two very different systems. When VTEC engages at a preset RPM the valve rockers begin to follow a higher profile cam lobe, but VVT-i does a continuous change to the cam angle (only on the intake side for the 2AZ). i-VTEC and VVTL-i would be closer in comparison, but even still the Emanage can't adjust the cam phasing part of the i-VTEC system, just the high profile cam cross-over point. The CamCon can adjust the cam crossover point for Honda's, but not for VVTL-i equipped Toyota's. It can adjust the cam phasing for VVT-i and VVTL-i, but not for i-VTEC. Strange, yes, but that's the way it works.
Edit
Engifineer beat me to it.
Old Jul 22, 2005 | 05:33 PM
matty-tC's Avatar
ahh comprendo. i guess that answers the questions that i was asking my tuner. he was under the impression it would do both.
thanks for the warning fellas
Old Jul 22, 2005 | 07:35 PM
-Keith-'s Avatar
Wheres the pics?
Old Jul 22, 2005 | 11:45 PM
Javier13's Avatar
well the camcon adjust the timing but doesn't control the vvt-i the air and fuel its adjusted there is no word on how to said it but the overall is that is great y have it and I will recomended a friend of mine has a apexi safc2 and there was no difference I still haven't gone to the dyno but I will be going soon so I can tune It . let me tell you that you have to tune the complete power from 500rpm to 7500rpm or your car will not work propertly
