xB foglights/switch/relay/plugs
Old Jul 29, 2005 | 02:18 PM
Lip's Avatar
Lip
Default xB foglights/switch/relay/plugs
As you can see from this photo...i'm not using the stock foglights.
the plug is behind the bumper from what i remember..i'm sure the switch plug is behind a blank in the interior.
my questions are...
I'm not willing to pay $40 to the dealer for a stock foglight switch...what have others used that fit great or did you just cut the tab and put your own?
Is the relay(which) in place already...if not...where in the engine bay are you plugging it into the stock harness?
Thanks in advance...the search engine here is difficult to get specific info from.
Old Jul 29, 2005 | 02:41 PM
Bgnome's Avatar
the relay does not come installed. there is an empty slot for it in the fuse box under the steering wheel.
you can use that switch from lowes that fits in the blank.
Old Jul 29, 2005 | 02:47 PM
Lip's Avatar
Lip
thank you.
do you happen to know which relay it uses and which Switch are you talking about from lowes?
tia
Jeff
Old Jul 29, 2005 | 02:56 PM
Dewmerz's Avatar
GSW-45 I think
Old Jul 29, 2005 | 03:06 PM
Lip's Avatar
Lip
thanks...yes thats it. which relay?
Old Jul 29, 2005 | 03:19 PM
jallamas's Avatar
Try www.painlesswiring,com for a selection of switches and I am sure they have relays.
jallamas
Old Jul 29, 2005 | 03:22 PM
jallamas's Avatar
sorry, its www.painlesswiring.com
Old Jul 29, 2005 | 07:11 PM
magicmanjk808's Avatar
heres a link to the thread with the switches in it. they fit perfectly
https://www.scionlife.com/forums/viewtopic.php?t=29672
Old Jul 29, 2005 | 07:16 PM
Bgnome's Avatar
i think i read somewhere that you can get the relay from toyota for around $8. i will be installing aftermarket lights as well and will see if i can find anything better..
Old Jul 29, 2005 | 07:24 PM
jallamas's Avatar
What sze are the switches?
Thx
jallamas
Old Jul 29, 2005 | 10:03 PM
Lip's Avatar
Lip
the relay they offer for those fogs is like 60bucks.
there MUST be a stock relay for that socket(when i find that socket...lol)
Old Jul 29, 2005 | 11:10 PM
ThunderGod's Avatar
here ya go!
https://www.scionlife.com/forums/vie...ighlight=gsw45
Old Jul 29, 2005 | 11:28 PM
Lip's Avatar
Lip
yeah i got the switches for 3.99 each...i need the relay
thanks
Old Jul 30, 2005 | 01:41 AM
Davestoaster's Avatar
The relay is a factory Toyota part your dealer can get. They are all the same so they always have them in stock.
To get to it....remove the drivers door sill plate and left foot kick panel. All just pull off. Then remove that little fuse panel pocket below the mirror adjustment switch. The relay is the 3rd down. It's blue, and missing. First, working from below in the kick panel area, remove the plug for the relay that is clipped to the fuse block. Slid it towards the engine and it just un-clips. Hook the relay to the plug and put it back on the clip. Be sure and check for the fuse for the fogs. Some were missing, some already had it.
The plug for the switch is taped to the wiring loom behind the ash tray.
Old Jul 31, 2005 | 01:23 AM
starrwulfe's Avatar
I like that WRX style airdam... where'd you get it from? Did the fogs come with it? (PM me if you have to-- this question should be in the aero section I think..)
Old Jul 31, 2005 | 03:00 AM
Lip's Avatar
Lip
we made it. we used a stock wrx bumper and a stock xB bumper. cut the fog housings and part of the bumper out of the wrx bumper and molded it into the stock xB bumper. it came out super clean.
