Painting Interior Pieces...
Old Jul 31, 2005 | 01:57 AM
wizzlexB's Avatar
Default Painting Interior Pieces...
Getting ready to dis-assemble (sp?) my interior, to a light extent, anyways, and am about to do some painting. One problem....I am new to painting automtive pieces of any sort!! I've seen primer, prep, and paint kits in JC Whitney, etc. Once I get these pieces off, do they need sanding? What's the process? How many coats are needed? Do I need to clear coat any of it?? I'm cluless!! Any help ot sources that I may look would be GREATLY appreciated!
Old Jul 31, 2005 | 02:22 AM
XB_BOB's Avatar
don't know but would like to find out
Old Jul 31, 2005 | 02:27 AM
BEASTXB's Avatar
check this out
https://www.scionlife.com/forums/viewtopic.php?t=6891
Old Jul 31, 2005 | 02:54 AM
Dewmerz's Avatar
moved
Old Aug 1, 2005 | 05:10 PM
n2htwlz's Avatar
Scion Apocalypse
If you are painting the silver parts, you wont need to sand them down. You can if you feel the need to, it wont hurt, but will create alot of scratches under the finished product. Clean them real good with rubbing alcohol or 'prep-all' wax and grease remover, be sure to get all of if any armorall type stuff off the plastic parts. Spray the parts with a adhesion promoter, you can get it in spray can form most stores. Just take your time and you will have a good looking end result.
Sorry I cant help in recomending any rattle can products for this, I use a base coat clear coat automitive paint out of a spray gun, all parts get 2-3 coats of clear for durabillity and high shine. If you need more help just pm or email me..
Old Aug 1, 2005 | 05:32 PM
Kilo6_one's Avatar
i would prep, primer 2-3 coats, and DONT forget to clear coat it, if you want to sand use 1100 or higher grit sand paper. ive painted chevy trucks interiors, and that is how we did it, use Duplocolor if you dont want to spend an arm and a leg, they sell everything you need......im pretty happy with duplocolor for small jobs.......bigger ones ill whip out the spray gun.
Old Aug 1, 2005 | 05:37 PM
chadfo's Avatar
I'm not going to comment on the paint part because that's already been covered by the experts.
I just want to throw in that the pieces look much better when they are sanded to remove the dimpled effect. Just make sure you don't use a heavy grit and scratch everything up. I think I used 600 when I did mine. It takes a little while to sand it with such a fine grit but that ensures there are no scratches to worry about.
Old Aug 1, 2005 | 08:16 PM
magicmanjk808's Avatar
here's a thread you should look at
Old Aug 1, 2005 | 08:45 PM
Lonely_Raven's Avatar
Hey, that's funny, that looks EXACTLY like the thread pointed out in the 3rd post!
Old Aug 1, 2005 | 08:49 PM
wizzlexB's Avatar
Thanks for the tips, I'll get on it. I'm doing Neon Green, if I find a shade I like. Post pix when I'm done..thanks...
mc1114
Scion tC 1G Aero & Exterior
Aug 10, 2015 10:34 AM
umnitza
Jul 25, 2015 07:54 PM
Garrettthepatwa
Scion tC 1G ICE & Interior
Jul 25, 2015 05:08 PM
StxArOne
Jul 13, 2015 06:25 PM
excessads
Jul 13, 2015 11:41 AM
