tC offset question for 17s ... will this offset work ?
Old Aug 6, 2005 | 05:06 AM
Soon2BxB's Avatar
Default tC offset question for 17s ... will this offset work ?
i was looking at a set of wheels and here are the specs
17x7.5 48 offset
i know stock for the tC is 17x7 45 offset...
will i run into issues trying to run a 48 offset on a 7.5 wide wheel ?
also .. will the stock 215 45 17" tires fit these wheels ?
thanx alot
Old Aug 6, 2005 | 06:51 AM
teksno's Avatar
yes... its 3 milimeters... probably not gonna mater that much. and im sure if you used the search function you would find a few tc's running with a 48 offset.
Old Aug 6, 2005 | 07:00 AM
Soon2BxB's Avatar
dont be so quick to assume that its not going to make a difference because its only 3 mm...
3mm could be the difference between fitting and rubbing ..
ie;
18x7.5 with a 42 offset on an xB works perfect ... but a 18x7.5 45 offset will hit the rear suspension ...
as for the search feature.. it sux plain and simple
but thanx for your response anyways
Old Aug 8, 2005 | 12:58 AM
Soon2BxB's Avatar
ttt
anyone help me answer this ?
TotalChaos
13
Feb 4, 2015 10:24 PM
gettoastedinthetoaster
Scion xB 2nd-Gen Wheel & Tire
Dec 29, 2014 11:39 PM
DR_xB
Jul 20, 2004 08:31 PM
smilygo
Oct 5, 2003 09:51 AM
Male_Nurse
Sep 27, 2003 10:59 AM
