Injen CAI mounting (vibrating) bracket ??
Old Aug 6, 2005 | 03:00 PM
rolstc's Avatar
Default Injen CAI mounting (vibrating) bracket ??
Ok i got installed the INJEN CAI. now the bracket you have to place in the fenderwell where the filter is is moving alot. The reason being is that the hole for the bracket no way in hell matches up with the hole to place it in to secure it. So i ziptied it with in the hole. It looked and seemd like it would do the job, but coming home from the install and at a stop light i would hear D-D-D-D-D-D-D-D where the end piping it banging on the finder repeativley.
Now my questions for you guys ..
was your mounting bracket easy to fit in place with the little hole ??
am i doing something wrong ??
what can i do to fix it ??
oh and pics would helps alot too !!
thanx
Old Aug 6, 2005 | 04:37 PM
lil_tC_boi's Avatar
sup duude...i installed my cai yesterday...my bracket on the ca lined up w/ where you were supoosed to put that vibra mount thingy...if i had my bumper still off i would take pics..what you hear that is makin that noise, is your fender and ur frame right there where you stuck it through...they sent me some rubber strips to put on the frame n fender so it doesnt vibrate against it...
Old Aug 6, 2005 | 05:01 PM
emiller's Avatar
k&n has the same problem. Anything to put between there should be ok. Make sure it can take a little heat though.
Old Aug 7, 2005 | 05:22 AM
rolstc's Avatar
no its hitting on the inner fender . i put the plastic peices around there and its not hitting the sharp edges. It's hitting where the fender is but inside. Right were the second pipe bends through the little hole.
Old Aug 7, 2005 | 05:42 AM
need4speed's Avatar
haha, you screwed up.
Old Aug 8, 2005 | 05:11 PM
rhythmnsmoke's Avatar
Music City Scions
Dude, something must be wrong. The clearance is good with the inside of the fender. You must have put the vibra mount in the wrong location or something.
Old Aug 8, 2005 | 08:27 PM
apexjr's Avatar
I had the vibration, but it was coming from the pipe touching with to much force the opening into the fender. I have the rubber pieces on each side *upper and lower* parts of the opening. I felt around and decided to just try to adjust its position. I loosened the upper mount and shifted the bolt on the mount towards the outside of the bracket and then tightened it back down. This effectively moved the pipe away from the lower part of the fender opening and reduced if not completely eliminated the vibration.
Give it a try.
Old Aug 8, 2005 | 08:48 PM
Music City Scions
Give it a try.
I went to Lowes and picked up a foam rubber insulation tube from the plumbing section. Cut a snip from it, and stuck it in where the intake meets the fender.
Cost of foam tubbing = $3.80
Satisfaction from no more rattling vibration = Priceless
For everything else there's Turbo's...lol
Old Aug 14, 2005 | 02:23 PM
aarontrini85's Avatar
i fixed it i think......
it didnt seem to hit the fender any more but let me know how it is on your drive back to chicago today
tpistoia
Oct 25, 2023 10:06 AM
maximthegreat
Jan 19, 2016 02:31 PM
Subaru86
Jul 31, 2015 04:00 AM
marsman328
Regional - Pacific Mid
Jul 28, 2015 09:43 PM
goatbelly
Jul 12, 2015 10:13 AM
