FOR YOU GLASS PROS...
Old Aug 9, 2005 | 02:45 AM
sensez's Avatar
Default FOR YOU GLASS PROS...
I can see a lot of surface scratches on my winshield like someone used a brillo pad on it. Is there anyway to remove superficial scratches from glass?
thanks
sen.
Old Aug 9, 2005 | 05:40 AM
sensez's Avatar
bump for help!
sen.
Old Aug 10, 2005 | 02:07 AM
jynx's Avatar
<~~~ glass pro
no really i am, i am a licensed glasier
You can try a glass polish.
Old Aug 10, 2005 | 02:13 AM
windowtint's Avatar
cerium oxide and a felt 'bob' on the end of a drill - the fun part is cerium oxide dust is highly hazardous to inhale and the heat in polishing can build rapidly and easily crack the windshield. party on.
seriously - yeah, it can be done - although if you've never done it, it'd be a better idea to find a local detail / glass shop that'll do it for you.
Old Aug 10, 2005 | 02:16 AM
chadfo's Avatar
I'd suggest either trying car wax or Rain-x first. They usually hide a lot of small imperfections and they will help water roll off when it's raining.
Old Aug 10, 2005 | 02:47 AM
sensez's Avatar
wax on glass?
i will try that...
wintint: i called some shop.. and they said theres no way to remove scratches from glass.. and i was thinking "bs, this secretary doesnt know poopie."
so its possible to remove superficial/light scratches from my winshield?
sen.
thanks fellas
Old Aug 11, 2005 | 01:42 AM
chadfo's Avatar
Yes, wax on glass. My cousin used to detail cars and he was the first to tell me about it. Then I saw it on the Mother's Car Show Tour tv show. Mr. Chemist did a segment on how the pros get glass ready for the show. First you wash the dirt and grime off, then use the finest steel wool you can get, at least 0000, then use your favorite car wax just like you would on paint.
Old Aug 11, 2005 | 06:49 AM
sensez's Avatar
yea.. i just asked some detail guy about it... and he said atleast triple 0 steel wool will buff the scratches out...
i wonder if theres a specific method to do so.. cause i dont want to eff up my glass even more
sen.
Old Aug 11, 2005 | 12:17 PM
TheIcon's Avatar
I always wax my windows mainly cause I want water to run off it similar to rain-x.
Old Aug 11, 2005 | 12:33 PM
Lonely_Raven's Avatar
Check this out. Your local detailer could do this, or you could take a stab at it if
you can procure yourself a Porter Cable.
http://www.properautocare.com/polglasus74p.html
I HIGHLY recommend the Porter Cable Random Orbital which can be picked up for
about $93 plus tax as Lowes hardware. I use it for polishing, buffing, and repairs of
the crappy Scion paint.
Old Aug 11, 2005 | 12:34 PM
chadfo's Avatar
I've never heard of steel wool actually buffing scratches out but it does clean it well. I also wouldn't suggest using 000 becaus it's more abrasive. Try to find 0000 or if you can 00000. I normally dip the steel wool into my normal wash solution because it acts as a lubricant, Mr Chemist used glass cleaner. Then lightly go over your windshield. It doesn't have to be in circles or any other particular motion. The key is lightly. Let the steel wool do the work. If you press down too much you will have more scratches. Then rinse, dry, wax or Rain-x.
From my personal experience Rain-x does a better job of letting water bead and roll of than regular car wax. It just depends on the chemical composition of the wax so some may work better than others.
Old Aug 11, 2005 | 12:43 PM
chadfo's Avatar
Steel wool and clay bar will do the same thing and is cheaper.
Old Aug 12, 2005 | 07:24 AM
sensez's Avatar
i just purchased 0000 steel wool from lowes...
whats the method?
wet glass and lightly scrub?
any help would be appreciated.. thanks
sen.
Old Aug 12, 2005 | 12:53 PM
chadfo's Avatar
whats the method?
sen.
That's pretty much it but don't scrub. Steel wool will tear your windshield up if you scrub. Just lightly run over it and the let the wool do the work.
Old Aug 12, 2005 | 11:57 PM
sensez's Avatar
wet dry? does it matter.
thanks..
sen.
Old Aug 13, 2005 | 12:06 AM
chadfo's Avatar
Has to be wet!!!!!!
Old Aug 13, 2005 | 03:33 AM
sensez's Avatar
wish me luck tomorrow
ill be heading to IICONZ® Torrance, CA to do some work on the box. =] and hopefully i'll be able to "see better" after we're done.
sen.
StxArOne
Scion xA Aero & Exterior
Apr 3, 2018 02:22 PM
Bimfi
Sep 4, 2015 08:15 PM
Wrencher
Jul 29, 2015 01:38 PM
SoCal_CJ
Scion tC 1G ICE & Interior
Jul 14, 2015 09:14 PM
KTamAK187
Apr 15, 2015 10:08 PM
