turbo install
Old Aug 19, 2005 | 07:07 AM
mikek6789's Avatar
Default turbo install
to install a turbo on a tc, is it neccassary to replace the head?
Old Aug 19, 2005 | 07:19 AM
kungpaosamuraiii's Avatar
Only if you really want to put the turbo on.. then yea.
Jibes aside, the turbo sits right on the header and is powered by the gases that come directly out of the block. Try:
http://auto.howstuffworks.com/
header - WOOPS
Old Aug 19, 2005 | 01:00 PM
matty-tC's Avatar
to replace the head? no it is not.
Old Aug 19, 2005 | 01:01 PM
matty-tC's Avatar
what are you talking about "really want to put the turbo on"?
he didn't say header
Old Aug 19, 2005 | 01:03 PM
aarontrini85's Avatar
and lest go with another no you will need to remove every thing that is before the throttle body sutch as intake piping and the airbox and also your exhaust manifold will need to come off other then that nothing should realy need to come off
Old Aug 19, 2005 | 01:08 PM
GoSwim's Avatar
The simple answer is no. Installing a turbo kit is just a really extensive remove/bolt-on project.
Old Aug 19, 2005 | 01:54 PM
Solarxb20's Avatar
^^^ What he said.
Old Aug 19, 2005 | 02:13 PM
TCguy8's Avatar
I was wondering if installing a turbo is easy enough to do at home in
your garage?
Old Aug 19, 2005 | 02:17 PM
Fm_Tc_In_Ma's Avatar
your garage?
I think those who ask if they can install it themselves..........shouldn't.
I mean no offense in saying that.
Old Aug 19, 2005 | 02:46 PM
Marshall's Avatar
The ZPI kit is fully "bolt-on" and have stated they like to think that "if you can change your own oil", that should able to install the kit. ZPI techs can perform the install in 3 hrs, a novice mech in 6 hrs, and a beginner mech in 6-8 hrs.
Old Aug 19, 2005 | 02:55 PM
On a totally different note, yet somewhat relavent.....the guide to installing the x86 version of osx is made to be simple enough for people who can browse the internet and read email. Well, do you know how many people can't get past the first step without being totally clueless?
Like I said..if you have to ask how to do it, your best bet is to have someone do it who knows how to.
Old Aug 19, 2005 | 03:06 PM
toastbox's Avatar
I'm gonna refine what people are saying:
if you have to ask if the head needs to be removed for a turbo install, you should not attempt this without guidance/help.
That's not meant to be an insult, or offensive, but one of the biggest problems I've seen in "do it yourself tuning" is people not knowing what they are getting into, because they don't have a clear understanding of what they are doing, or how things work.
Old Aug 19, 2005 | 04:07 PM
your garage?
you have to try to learn i would do it my self but that is just how i am
Old Aug 19, 2005 | 05:37 PM
mikek6789's Avatar
i read a tutorial and they took the head and gasket off and i was like wtf o.O
so i was wondernig if that was neccassary for the tc..
Old Aug 19, 2005 | 06:27 PM
who took the head off??? zpi??? if it was zpi they probly but a there stage 1 head on there along with the turbo other then that there is no real reason to do it unless there doing the headgasket stacking i have seen some ppl do on honda-tech.com
Old Aug 19, 2005 | 06:34 PM
reagulator's Avatar
our compression ratio is not as high as an honda so i dont think stacking gaskets is needed
Old Aug 19, 2005 | 07:44 PM
GoSwim's Avatar
your garage?
The simple answer to this question is yes you can install it in your home garage (with proper tools of course), but there is nothing easy about it.
Old Aug 19, 2005 | 07:48 PM
i dont realy see what would be hard it just seems time consuming probly the only part that would realy suck woudl be draining the oil pan and making the hole to feed oil to the turbo every thing else just seems to bold in to place
or am i missing a realy big step??? maybe wiring up the piggy back ecu but thats only hard becouse im red green color blind
Old Aug 19, 2005 | 08:30 PM
matty-tC's Avatar
you are correct, sir.
you would only lower the compression ratio if you were building up the engine for big boost (1 bar +)
Old Aug 19, 2005 | 10:35 PM
mikek6789's Avatar
LMFAO!!!
