Need DC Sports Strut Bar Torque, plz
Old Aug 25, 2005 | 02:30 AM
Susanto_Agus's Avatar
Default Need DC Sports Strut Bar Torque, plz
I lost my instruction paper to install the DC Sports Strut Bar. Can somebody tell me how much is the torque ?? Thx.
Old Aug 25, 2005 | 02:31 AM
ack154's Avatar
Moved to CC...
Old Aug 30, 2005 | 06:41 AM
still waiting ....
Old Aug 30, 2005 | 10:36 AM
designone's Avatar
I just checked my directions.....(torque: 6.0 kg-m, 43 lb-ft)........hope this helps...
Old Aug 30, 2005 | 01:49 PM
BOXMAN's Avatar
yeah its 43-45 dont just guess use a torque wrench
BOXMAN's Avatar
Old Aug 30, 2005 | 03:22 PM
Marshall's Avatar
Make sure you lift the front chassis for preloading, before you install the strut bar or you wont gain the full added benifits of having this mod.
Old Aug 30, 2005 | 04:02 PM
maximus96's Avatar
if you lift both wheels off the ground, then take the top 3 nuts off the strut, won't the strut fall down? what is holding the strut up high enough to expose the threads on top?
Old Aug 30, 2005 | 05:14 PM
Marshall's Avatar
Good question, I will rephrase my statment better. You just need jack up the front end of the car for preloading the chassis.
Old Aug 30, 2005 | 05:42 PM
unlimited77's Avatar
^^ i still dont understand your statement clearly.
Do you mean to jack it to a point where ur tires can rotate but little or hardlt any room for the wheels to fall down?
Old Aug 30, 2005 | 07:57 PM
Marshall's Avatar
Yes, basically as far as you can while still being able to attach the strut bar. Just enough lift for pre-load.
Old Aug 31, 2005 | 08:47 AM
Thx guys. One more question bout the third nut, do i tighten it using the 43 lb of torque too?
Old May 19, 2006 | 11:37 PM
Spect2K3's Avatar
Sorry to recall an old thread guys, but doing some searching, I've come across a question:
Normally, the top mount on the strut is to be torqued to 38 ft lbs. I recall this from doing the springs. When installing the dc bar, it should now be torqued up to 43ish??
Old May 20, 2006 | 12:00 AM
Spect2K3's Avatar
maybe a BUMP is in order, who knows?!
Old May 21, 2006 | 02:21 AM
Spect2K3's Avatar
One more BUMP, someone help me out here
xa007xa
Feb 26, 2015 02:12 AM
xa007xa
Feb 22, 2015 02:56 PM
AxRxP
Jan 25, 2015 08:40 PM
DJ_X_Trodinaire
67
Feb 11, 2005 04:38 PM
