3RZ-FE ?
Old Aug 25, 2005 | 06:00 AM
jd74's Avatar
Default 3RZ-FE ?
Im looking for some information on the 3RZ-FE. This is the engine in the Tc drag car but is generally found in your average Toyota Tacoma. Any information is usefull information!!
Old Aug 25, 2005 | 01:27 PM
matty-tC's Avatar
3RZFE
150hp@4800
177ft-lb@4000
4 cylinder
2693cc
Electronic Fuel Injection
9.5:1 compression
95 bore / 95 stroke
Old Aug 25, 2005 | 05:41 PM
jd74's Avatar
Has anyone seen or heard of this being swaped into a Tc?(OTHER THAN THE DRAG TC)
Old Aug 25, 2005 | 05:57 PM
matty-tC's Avatar
i haven't.
ask rado
Old Aug 25, 2005 | 07:47 PM
hahaitzskippy's Avatar
matty where did you get his info from.
cuz i went to toyta myself and saw the inline-4 engine for the tacoma and i remember i the engien code started with a
"2" and not a 3.
unless we are talkin about the older model...
Old Aug 25, 2005 | 08:56 PM
matty-tC's Avatar
1996-present .... 3rz-fe is the 4 cylinder used
1996-present .... 5vz-fe is the 6 cylinder used
www.google.com
Old Aug 26, 2005 | 05:55 AM
jd74's Avatar
I guess you guys can see were I am going with this.(a 3RZ-FE swap) Just doing research to get some ideas and info. This could potentially be fun and very unique project!!!!
Old Aug 26, 2005 | 02:16 PM
matty-tC's Avatar
unique but honestly man the 2az-fe is a mother-f'er of an engine.
proven to be very strong and responsive to mods. if you put your energy/$ into hooking up your current engine, you'd be very rewarded.
Old Aug 26, 2005 | 03:51 PM
its not the engine
i thought about this for the DRIVETRAN! RWD
Old Aug 26, 2005 | 03:56 PM
Lonely_Raven's Avatar
Interesting...someone's got some money to burn I figure.
Old Aug 26, 2005 | 04:05 PM
matty-tC's Avatar
Originally Posted by hahaitzskippy
its not the engine
..... find an empty tC chassis and figure out where you're going to put the driveshaft and what you're going to do with the rear suspension... last i remember they're leaf springs on the trucks.
Old Aug 26, 2005 | 04:31 PM
seminoles68's Avatar
I would rather have a 2jz motor in the tc instead of the 2az
Old Aug 26, 2005 | 04:35 PM
matty-tC's Avatar
lol
yeah.. so you could race from a roll
Old Aug 26, 2005 | 04:53 PM
rockbrawler884's Avatar
Originally Posted by matty-tC
lol
Old Aug 26, 2005 | 05:26 PM
engifineer's Avatar
Yeah, you're not really gaining a ton with that swap. Just build what you have. That engine may be a little more "heavy duty", but you arent attempting to build a 1000 HP car.
Now, for the RWD, considering the larger cost of making it work on the tC, you would probably be just as well off cost-wise finding a RWD tranny to mate up to the 2aZ with some modification rather than swapping engine and all. The suspension should not be a terrible issue if you find a rear end that will work. But there will be a ton of cutting/welding to do to make it all happen. It would be a kick a$$ car though if someone had the money to dump in making it RWD.
Old Aug 26, 2005 | 05:56 PM
jd74's Avatar
It would be an expensive project!!! Rear wheel drive Tc would be killer but that seems to be something toyota leaves up to lexus.
Old Aug 26, 2005 | 06:35 PM
matty-tC's Avatar
not sure the engine would fit when set at 90 degrees of what it is now. but i don't believe there is a rwd tranny that would fit.
Old Aug 26, 2005 | 06:39 PM
The_Instigator's Avatar
If you want a RWD tC like car, just sell your car for an IS300 and mod it out. Youll probably end up saving money in the end and overall the car would still be better. Seems to me the gains arent woth it but its your idea...not mine.
Old Aug 26, 2005 | 06:57 PM
matty-tC's Avatar
insurance on lexus cars is ridiculous
Old Aug 26, 2005 | 07:09 PM
Oh...well thats the dealbreaker then.
Cuz im sure an engine swapped RWD coverted tC would be easy to insure
