tapping from the bay after tower bar install
Old Aug 26, 2005 | 03:54 AM
stillmotion's Avatar
Default tapping from the bay after tower bar install
I just installed my dc strut tower bar and now I am hearing this tapping coming from the bay. I'm pretty sure that it is something tapping off of the bar. Has anyone else encountered this? I tried to search for a topic but nothing was showing.
any suggestions?
still
Old Aug 26, 2005 | 01:35 PM
dink10's Avatar
I have a DC sport tower bar and it makes a tapping noise at idle.
I'll investigate.
Old Aug 26, 2005 | 04:56 PM
slammed's Avatar
leave some tools in your engine bay? Have you shaken the bar with your hand?
Old Aug 26, 2005 | 06:08 PM
nope bar does not shake. no tools under there... i believe it is the harness that rests right next to the front tire well. im just not sure what i can place between then to cut back on the vibrations
Old Aug 27, 2005 | 02:09 PM
slammed's Avatar
not sure what harness you are talking about but I bought some sticky weather molding stuff at home depot that is sticky on one side and the other is soft cushion. I bought it to prevent my CAI from rubbing against the inside of the hole that the pipe goes through. Ill try to get some more info...
Old Aug 27, 2005 | 04:30 PM
Streeter's Avatar
I have the same issue and it's driving me nuts. Some people have posted about it and "fixed it" but it doesn't really fix it for me. Maybe I haven't found what he was talking about.
Originally Posted by jrv2000
I use to have this problem too, here is how you fix it. Look at your strut bar closely. You will notice that there is a little connector attached to the intake that is touching the strut bar. When you turn on the car, the intake vibrates, which causes that little connector to bump against your strut bar, which makes that ticking noise. Just undo the screw that is holding the connector to the intake, and zip tie it somwhere else, and your problem will be solved.
Give it a try and let me know if that helps at all.
Old Aug 27, 2005 | 05:05 PM
dieselstation's Avatar
i know the fix!
there is a piece of plastic that sits right beneath the bar that vibrates when the bar is installed. What i did was tore up an old rubber mousepad and placed it right under it and secured it with double sided tape.
problem fixed!
Old Aug 27, 2005 | 05:11 PM
Streeter's Avatar
Hm. I must not have used a thick enough pad. I got some thicker weather stripping now so I'll go try that.
Old Aug 27, 2005 | 06:18 PM
Streeter's Avatar
As I figured - my tapping source is different, but it started when I put the strut tower bar on (the same one even).
When the engine gets hot, and the radiator fan comes on, you can hear a vibrating under the hood - you can hear it really well if you put your ear down by the front drivers side wheel. The noise is very noticable when you're at idle from the outside after driving around awhile. (My dealer said "What's that noise??") You can hear it inside the car when you're at a stop light or otherwise at idle. It gets quieter or stops when you turn the air conditioner off. It stops when you go, but I figured that was because the vibrating just gets faster and engine gets louder.
What do you think THAT is all about? Dink10 i'm anxious to hear what you come up with.
Old Aug 27, 2005 | 08:15 PM
I just ordered a new intake... d oyou think that the tapping will continue one the new intake is in and offers more space? and draven do you have an intake? that could be causing the tapping
Old Aug 27, 2005 | 09:53 PM
Streeter's Avatar
Na, no intake
Old Aug 28, 2005 | 03:57 PM
I will attempt the fix on mine today and listen to see if there is anything else. I'll keep you posted.
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
JPuehl
Jan 10, 2015 01:01 AM
hampton1100
Jan 2, 2015 08:13 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
