15" and 16" offset question...xb
Old Sep 3, 2005 | 02:15 AM
Burn0ut's Avatar
Default 15" and 16" offset question...xb
Hey I was wondering if any of these ofsets and sizes would cause any problems.
15" x 7" : +27, +38, or +45
16" x 7" : +29, +38, or +44
16" x 8" : +35
which of these would work...and which would work best (most flush)?
Old Sep 3, 2005 | 04:04 AM
Derk-xB's Avatar
As I understand, if you're getting a 7" wheel a 40 offset or less (38?) is ideal.
Someone please correct me if I'm wrong.
Old Sep 3, 2005 | 05:39 AM
stankubrick's Avatar
+27 would be the best of those choices. It's hard to find low offsets.
Old Sep 3, 2005 | 05:58 AM
squirrel's Avatar
I wouldn';t get any offset +40 or higher.
As Rico stated, the lower positive offsets are best and finding a +27 is practically gold. You can run almost all suspension set-ups w/ that offset.
Old Sep 3, 2005 | 06:37 PM
chucksu's Avatar
Default Re: 15" and 16" offset question...xb
16" x 8" : +35
All would work.
The one that would be most flush is the 15x7 with the ET of +27 You probably would still want to run like a 5mm spacer on the back, because the back wheel tucks in about 3mm more then the front.
Old Sep 3, 2005 | 07:03 PM
nineohtoo's Avatar
My TE-37's are 15x7 +43 and I haven't run into any problems. the guys who installed it didn't say anything either. BTW, ride is not flush at all lol. I don't like that.
Old Sep 3, 2005 | 08:00 PM
chucksu's Avatar
Get some spacers on those back wheels!!!! With the 15" wheel there is not much of a problem. With 16" + there is part of the suspension that the wheel will rub with that kind of offset. https://www.scionlife.com/forums/viewtopic.php?t=79549 that topic has pics of damage caused by the problem. The xB has the exact same problem. So to be on the safe side, I would go make sure your tire/wheel is not rubbing on that thing.
Old Sep 3, 2005 | 09:10 PM
bBOXD's Avatar
15" x 7" : +27,
Thats the winner! Run a OTG rear Spacer shim and you'll be good.
Old Sep 4, 2005 | 05:54 PM
Burn0ut's Avatar
ok just for the sake of figuring out this thing; a 16" x 8" would be .5 inches (about 12.7 mm) wider on each side of dead center (0 offset) than a 16" x 7" rim right? (because its an inch wider) So a +35 offset would be pushed out like a car with a 7" rim and a +22.3 offset right? (+35mm - 12.7mm = 22.3) Just wondering...
Old Sep 4, 2005 | 11:21 PM
Burn0ut's Avatar
anyone?
Old Sep 4, 2005 | 11:47 PM
superjeer's Avatar
yes
Old Sep 5, 2005 | 05:05 AM
ScionPsyche's Avatar
I have some 15X7 Konig Rewinds with a +40 offset. The stock 185/60 15 tires are on them I was amazed how little clearance I had from my rear suspension. This picture shows that I couldn't even fit the tip of my index finger between the rear suspension and tire:
I put on One ton Garage spacers:
Now I have about 15mm clearance instead of about 5 mm. I can't believe how little clearance the stock tires had. The OTG spacers are very high quality and not very hard to install:
Clearance after adding spacers:
Old Sep 5, 2005 | 10:16 AM
chucksu's Avatar
How long did it take you to install the spacers?
Old Sep 5, 2005 | 12:08 PM
[quote="chucksu"]
It took me about an hour. I could do it in half that time now. The instructions that came with the spacers were pretty clear. I would suggest taking the brake drums off even though the instructions don't tell you so. It makes the brakes much lighter and easier to handle, and it also makes it really easy to line up the bolt holes in the axle with the holes in the spacer.
Old Sep 5, 2005 | 06:35 PM
You are correct. On an 8" wide rim offset +35mm, the outer edge of the rim will be pushed out like a 7" wide rim offset +22.3mm, BUT the inside edge of the wheel will be pushed in like 7" wide rim offset +47.7mm (+35mm + 12.7mm=47.7).
As you can see in the pics posted above, 15x7 +40 gets pretty close to the suspension...so 16x8 +35 would be even closer by 7.7mm......
Old Sep 6, 2005 | 06:38 AM
Burn0ut's Avatar
If I decided to go with the 16" x 7" with a +29 offset, could i run otg 5 mm spacers in the front and back without it sticking out?
Old Sep 6, 2005 | 06:46 AM
No problem, you'd probably need another 15-20mm on top of that before you start sticking out...
Old Sep 6, 2005 | 07:04 PM
eXciteBox's Avatar
Signature Visions
listen to Rico, he knows his stuff about fitment
i thought my wheels were flush til i saw his car, and im running +25!
Old Sep 7, 2005 | 07:23 PM
Bull's Avatar
It seems to me that the 16x8 +35 would be the closest to flush of the bunch. Add the OTG shims in the rear and you'd be set.
xBrelease08
Scion xB 2nd-Gen Wheel & Tire
12
Feb 29, 2016 05:39 AM
terrye
Sep 26, 2015 12:24 AM
xBrelease08
Sep 13, 2015 04:39 PM
umnitza
Sep 1, 2015 08:06 PM
TOOSLOW
Jul 25, 2015 05:19 PM
