Oil filters (different heights WTF?)
Old Sep 6, 2005 | 12:50 AM
cpa5oh's Avatar
Default Oil filters (different heights WTF?)
I just did my first oil change (because no one will do it with Mobil 1 or Royal Purple...don't want Valvoline or Pennzoil in my car.) The filter that came off said "Toyota" on it (this was from the factory) and I put a Fram (the more expensive one) on.
The Fram was a good inch (or more) shorter than the Toyota...anybody else notice this? Wonder why they'd be smaller?
Old Sep 6, 2005 | 01:07 AM
LED-Maniac's Avatar
thats cause its a fram!
FRAM is absolutely one of the crappiest filters u can buy.
Its a proven fact they skimp on parts and use less filtering media.
I would def recommend using a factory filter or going with purolator or mobil. FRAM used to be good until they were bought out and went cheap.
Old Sep 6, 2005 | 02:33 AM
The_Instigator's Avatar
Most the filters you can buy will be a lot shorter. For some reason the factory model is longer than the size speced for our car. Do a search in the maintainence section and youll see a lot more about it.
Old Sep 6, 2005 | 03:20 AM
reagulator's Avatar
the filters from japan toyota are taller then the american toyota filters. you can find japan filters at mcgeorges
Old Sep 6, 2005 | 03:24 AM
Revilo's Avatar
What about K&N filters?
Old Sep 6, 2005 | 01:25 PM
Brent_23M's Avatar
Sometimes factory is better, ecspecially with Toyota's.
Old Sep 6, 2005 | 03:33 PM
ILLCRXSI's Avatar
fram sucks, and as far as k&n, well i can't think of anything that would justify a $15 oil filter. the k&n probably has the same exact crap on the inside as a purolator.
Old Sep 6, 2005 | 08:04 PM
scoobybri's Avatar
Purolator Pure One...great filter. You can get them at Pep Boys for around $6.
Old Sep 7, 2005 | 12:16 AM
Max's Avatar
Max
I spoke with the parts guy at the local dealer, and he said Toyota uses two filters for the 4 cylinder models. Either will fit, but since there is room for the longer one on the xB, that is the one they go with.
The longer one is Part# 90915-YZZF1. I'm not sure about the shorter one.
To echo what ILLCRXSI said, FRAM is awful. Go replace it now.
Read this: https://www.scionlife.com/forums/viewtopic.php?t=80737
Old Sep 7, 2005 | 12:26 AM
bblhed's Avatar
Fram? That thing is all paper inside! you would have been better off spining the old one back on.
Old Sep 7, 2005 | 12:51 AM
jct's Avatar
jct
can't forget about the WIX (51394) / Napa (1394) filters (there the same filter)
i enjoy using wix oil filters alot
Old Sep 7, 2005 | 05:35 AM
sciontc_mich's Avatar
fram USED to be good, but that was like 10 years ago.. since then they've turned to crap.. if you want your engine to work, STAY AWAY from fram...
yeah toyota's filters are pretty good, when you see the "competition" sheesh..
Old Sep 7, 2005 | 06:28 AM
Tomas's Avatar
Admin Emeritus
Please, cpa5oh, use the Toyota filters (or at least another top-end filter, but Toyota are actually BETTER than most other top end filters). Stay away from Fram.
Your tC will thank you.
Fram now makes some of the worst 'national brand' filters available.
There are race engine prep folks that use Toyota filters for race applications on non-Toyota engines because they are so good. (Some even modify the mountings to take Toyota filters...)
Old Sep 7, 2005 | 03:25 PM
bblhed's Avatar
Wix, that was the one I couldn't remember, it is teh came as a NAPA Gold.
Old Sep 7, 2005 | 08:54 PM
jboogz's Avatar
Factory or K&N! period!!
eric_m
79
Mar 17, 2013 12:21 AM
c_dog
40
Feb 2, 2005 12:08 PM
westsype
Sep 27, 2004 12:41 PM
captain_barkey
Mar 3, 2004 07:20 AM
NemoBronsky
Mar 3, 2004 04:47 AM
