question about tein basics
Old Sep 8, 2005 | 09:11 PM
FuN_b0x408's Avatar
Default question about tein basics
so i just lowered my xb on the tein basics. when i turned the adjusters all the way down the rear was higher than the front.
did this happen to anyone one else?
Old Sep 8, 2005 | 09:38 PM
Silencei2's Avatar
Yes, according to Tein specs, the rear can only be adjusted from 1.4-2.6 as opposed to the fronts which can only be adjusted from 1.6-2.8 so you're looking at a .2" difference in ride height.
Not to mention that the springs need to settle a little and since there is not as much weight in the back as there is in the front, the rear springs will more likely take a little longer to settle.
Another thing to look at is that the front lip is lower than any of the lips on the car by .5" or so. The front will always look lower unless you change the lips.
Old Sep 8, 2005 | 09:42 PM
driversdriving's Avatar
Read your specs. The fronts can be lowered more
than the rear can't it? Say the fronts have 2" total
adjustment and the rears have 1.5". If you lower the
the adjustments all the way the front goes lower with
the rear being higher? Right?
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
