Disable seatbelt blinking light?
Before anyone can be a wise guy I'll answer my own question by saying that the easiest way to disable the blinking seatbelt light is to put on your seatbelt.
I'll sometime leave my car on(A/C!!) and sit in the car while my wife runs into the store or if I'm in my driveway or driving across the street to the basketball or tennis courts. The blinking seatbelt light gets on my nerves. Is there a fuse that will disable the blinking of that particular light? If not, is the only other way to disable it by taking off part of the front dash and getting behind there and removing the bulb or covering it up w/electrical tape? Any suggestions on how to disable the light?
Just buckle the seatbelt when she gets out. You could take the thing apart if you wanted (it's fairly easy, just look at the thing and carefully take it apart), but it wouldn't really be worth the trouble.
Music City Scions
You could always go to the junkyard and find the end of the seatbelt that plugs in and use it as a dummy. That would shut off the light and still allow the airbags to deploy.
max2k: i take MY seatbelt off when i'm sitting in the car w/it running as well.
jethro: i don't want to get seatbelt clips fromt he junkyard and plug and unplug them. a simple answer like taking out a fuse or putting a piece of black tape over the inside of it is probably the answer. i'll look into it tomorrow.
The fasten seatbelt light can be caused not to blink by instructing the car's 'puter not to blink it. The instructions have been on ScionLife several times, but I am NOT going to guide you to them.
Just fasten the belt, look the other way, or set something on the dash in front of the light...
am i mistaken to say that the connector that senses a seatbelt that is fastened is beneath your seat? maybe you can unplug the connector and put a jumper wire in it..
agreed. i don't want to get into rewiring and getting all crazy. unplugging a fuse, removing a light or putting a piece of black electrical tape over the inside of the dash is about as far as i want/should go.
(1) That fuse has a whole lot of things on it.
(2) The "light" is a soldered-to-a-circuitboard LED.
(3) Black electrical tape will work - inside or outside the display.
(4) Since the computer can be instructed by the end user not to light the light in the tC, I suspect a similar set of steps exist for the xA and xB.
Music City Scions
Tape inside might get hot and melt. If you are going that far why not just pull the 2 bulbs and be done with it.
It originally sounded like you didn't wan't do anthing hard. Thats why I suggested the other thing. My bad.
i may pull the light. i'm trying to avoid that though b/c the light is soldered in their to a circuit board. if i ever sell the car in the future i don't want the buyer to ask, "why isn't that light lighting up? i need the light there." then i have to go through a process of soldering a light back on there. reprogramming it, taking out a fuse or using some tape is definitely my preference.
since i would imagine the little LED light can't get too hot a piece of tape inside may not be all that bad. hrm.
Music City Scions
Yeah, since they are leds tape should do the trick. I'm going to try that on mine.
OK, I really don't like assisting in disabling a federally required safety feature, so this is absolutely as far as I go in assisting.
Try the ...[EDIT]...
Or just put black tape on the back of the display window...
(Of course you realize if you then forget to fasten your belt there is NO guarantee the airbags will fire, either.)
You're on your own.
*washes hands*
You're on your own.
*washes hands*
jethro: i was thinking the same thing. believe me, if i ever sell the car i won't be mentioning some of the little mods i've done. =)
i went to take some of my dash off the other day. i took part of it off by pulling out the part around the speedomoter. as i moved down i noticed there was a little screw in there but i wasn't sure how to get that off so i could completely remove it and get more access. has this already been discussed?
tom, hehe. thanks. i thought about the federal requirements and i thought i was leaning on the laws but not going over the line since my intention isn't to disbale the seatbelts but just get rid of the annoying light. thanks again! you rock!
Unless they have had an xB, they wouldn't even know about the light. So why tell them about it. lol
That's one of many things I check in a used car...
