outside mirror disassembly question
Old Sep 15, 2005 | 03:35 AM
eggie's Avatar
Default outside mirror disassembly question
Does the mirrors simply pop out from the housing with a good tug or is it secured some how from the backside?
Old Sep 15, 2005 | 04:42 AM
UnFocused's Avatar
If you are refering to the mirror glass, yes it pops out.....
Old Sep 15, 2005 | 04:50 AM
windowtint's Avatar
...more or less. There are some small tabs in there that you pry against. Have done it a few times, I believe there's something in the DIY tech section that covers it.
Old Sep 15, 2005 | 02:14 PM
eggie's Avatar
Yes, referring to the mirror (glass) itself. Removing the actually mirror from the mirror housing/cover.
Didn't see anything in the tech section...
Old Sep 15, 2005 | 02:36 PM
dgHotLava's Avatar
here are a few shots of mine...
does this help???
moved to drag co.
Old Sep 15, 2005 | 03:03 PM
eggie's Avatar
yes, kind of... How did you get to the tabs. Just push the mirror upward and work on that adhesive stuff? I see tabs, but don't understand there direction.
Old Sep 15, 2005 | 03:18 PM
dgHotLava's Avatar
yeah, just pull from the bottom of the mirror. you can see the two clips and put a screwdriver in ther to help pry...
the adhesive stuff will strech a bit. just go easy, it takes a few mins to do each one...
Old Sep 16, 2005 | 03:42 PM
PlanoBob's Avatar
Can I ask what you are doing? What is the upgrade you are adding to your xb that requires removing the mirror? Thanks
Old Sep 16, 2005 | 03:55 PM
06B0X's Avatar
I'm glad someone posted up asking that question because I really want to buy the following for my xB.
Old Sep 17, 2005 | 12:40 AM
eggie's Avatar
Thinking about adding the JDM mirrors with turn signals.
Old Feb 1, 2007 | 10:43 PM
bb20inches's Avatar
after you removed the mirror and did the change over what did you use to glue it back on
Old Feb 2, 2007 | 12:41 PM
dgHotLava's Avatar
the mirror is held in place by the clips, not the glue.
but the glue is soft and will re-adhere when put back together.
Old Feb 3, 2007 | 05:16 PM
vintage42's Avatar
Default Re: outside mirror disassembly question
From a previous thread with photos:
"Push the top of the mirror back to tilt it all the way up. Then use your fingers or a screw driver to pop the bottom the mirror out, (there are 2 clips on the bottom of the mirror and then the top hinges will just pull out.)"
https://www.scionlife.com/forums/vie...ve+side+mirror
Old Feb 3, 2007 | 05:23 PM
SquallLHeart's Avatar
people need to pay a little bit attention more to the dates...
Old Apr 9, 2007 | 12:29 PM
HoTBoX009's Avatar
Great thread, thanks for the info!
Old Apr 9, 2007 | 06:18 PM
vintage42's Avatar
the mirror is held in place by the clips, not the glue.but the glue is soft and will re-adhere when put back together.
I think the glue holds the mirror to the backing plate that pops out.
It looks like someone did know the technique for popping the mirror out, and so pried on it until it came unglued from its backing plate.
Old Apr 9, 2007 | 08:45 PM
dgHotLava's Avatar
i think your about 90% right on that...
the glue looks to hold the mirror to the black frame.
but it also looks like it should stop and small vibrations to the movement base...
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
jairolla_89
Apr 2, 2015 09:41 PM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
