AEM or INJEN cold air intake
Old Oct 9, 2005 | 01:25 AM
iammarine77's Avatar
Default AEM or INJEN cold air intake
which one should i get?
Old Oct 9, 2005 | 01:28 AM
TimmyT's Avatar
Scion Society
Erm well the AEM isn't available for purchase and I don't think it will ever be. The TRD intake is pretty much a rebadged AEM intake, (Wich may not be released either) and cost around 400 bucks. If the TRD is released it will be 50 state legal. While the Injen is currently not carb legal. Hope this helps
Old Oct 9, 2005 | 01:44 AM
STATUS's Avatar
none GO WITH FUJITa... You will be Highly pleased with performance and looks... www.f5air.com
Old Oct 9, 2005 | 06:01 AM
kungpaosamuraiii's Avatar
Here's what I said to someone else on this board, hope this helps:
Originally Posted by I
MAXAM, the best gains come from something REALLY cold. The coldest thing that doesn't heat up that fast and is pretty cheap is water.
Here's an easy mod with big gains. It's a little known technique (about as little known as attaching a hose to your airbox to vent cold air in) called an airbox to waterbox conversion.
Plug up your airbox and fill it with ice water. The more water, the less heat change there'll be so the water will stay colder if there's more. Also, while filling up the box, water will go down the intake tract which is OK because the throttle body will still be closed. You just need to be sure that you have enough water to fill the intake tract AND the box. This is because the water in the intake piping will get combusted very quickly. The reason for this is that the water in the piping will already have passed the filter (the air filter works just fine as a water filter but a simple mod would be to get one from a Brea water filter system for tap water.) That first rush of water is good because on water intake the engine needs that much water to start turning. After that, the engine will take in only enough water to make power.
Think about it, people have been making 5 or so whp gains with a decrease of intake temperature of about 10 or so degrees. That is still 90 degrees. With ice water, you'll have intake temperature at around 30 or 40 degrees.
There are some aftermarket airbox-waterbox conversion kits but they are hard to find and really only consist of material to plug the airbox. A fancy kit will have an ice maker that dispenses into the airbox.
Try this way and then tell us of the gains. If you don't feel the gains, post another three or four threads asking about intake options.
Smile. Be amused.
Old Oct 9, 2005 | 06:06 AM
superbill's Avatar
Smile. Be amused.
SWEET JESUS THATS FUNNY!!
hampton1100
May 28, 2015 07:32 AM
bktply
Mar 17, 2015 04:50 AM
miguelishu
Mar 9, 2015 02:38 AM
AxRxP
Jan 25, 2015 08:40 PM
Hardhitten
22
Nov 13, 2003 11:53 PM
