CRUISE CONTROL
Old Oct 12, 2005 | 02:13 PM
CMDCM's Avatar
Default CRUISE CONTROL
Has anyone successfully installed (or had installed) a cruise control on xA? Just purchased an '06 with a 70 mile commute. Should would be nice when not in traffic to set the cruise.
Old Oct 12, 2005 | 02:34 PM
zinczipper's Avatar
Default cruise
...have had several cruise installed..I use the one made by ROSTRA
...www.rostra.com
...if you know what you are doing , you can install yourself . if not , don't try .
...I get $395. ( patrs & labor )
...tech info : wiring changed from '05 to '06
Old Oct 12, 2005 | 04:34 PM
Kremtok's Avatar
Rostra unit is in my car, and is very good. I just had the dealer install it before delivering the car. I've only had one problem, and that is the throttle cable sticking sometimes after using the cruise control. It's only moderately annoying, though.
Old Oct 12, 2005 | 11:26 PM
devilman13's Avatar
got my at the dealership and had them install it..works fine for me
Old Oct 13, 2005 | 01:20 AM
knuckleDragger's Avatar
I have an 06 on order in the LA area, the dealer told me there is no cruise control available for it. I will ask him if they will install the Rostra model.
I know this is a lot of car for the price, I think in the interest of fuel economy, they'd put cruise control in and bump the price up a couple hundred. No biggie, I'll find one, one way or another, and get it installed.
Old Oct 13, 2005 | 01:39 AM
Bgnome's Avatar
the dealer option is only available in select areas. i thought it was gulf states, but i guess not. it is the exact same thing as the rostra aftermarket unit.
Old Oct 13, 2005 | 02:27 AM
neotim's Avatar
I'm in the Gulf States Region, and my xA, which is on order, is supposed to arrive with cruise installed at the port. Actually all of my ordered accessories (except for tint) is supposed to be installed at the port (roof rack, wing, bumper pad...)
Old Oct 13, 2005 | 05:39 AM
Kremtok's Avatar
Gulf States it is I bought my car in Florida and had it shipped here.
Old Oct 15, 2005 | 10:18 PM
flyerI's Avatar
Installed the Rostra myself. Easy as pie if you have ever done anything like that before. Can purchase from Allscion.com. Be sure to ask them for the correct wire connections at the ECM as the 06 has changed pin positions.
Old Oct 16, 2005 | 04:08 AM
CMDCM's Avatar
Great comments and suggestions! I called a couple dealers in Riverside county but none will install for me. I found a vender who said it's a two hour job and only five wires. Perhaps I'll attempt. I'll make a few calls to some local repair shops and see if they'll install. Rather pay for experience then screw something up myself.
Old Oct 16, 2005 | 04:38 AM
Tomas's Avatar
Admin Emeritus
Just in case you want to look at the install manual for the Rostra in the xA/xB, here it is...
http://tijil.org/cruise_control.pdf
Old Oct 16, 2005 | 08:33 PM
flyerI's Avatar
The manual is a little confusing but on the Allscion site there are some notes by two or three guys that have installed it. After reading their comments the manual seemed pretty straight forward and with their input the job was even easier. Like I said in the previous post the speed sensor and nss wire are not in the same position on the connectors but the speed sensor wire is the same color as in the instructions. If you have a 5 speed that will be the only change. You will need a 10mm socket and a coupe of 12mm open end wrenches.
Old Oct 17, 2005 | 01:25 AM
bblhed's Avatar
I could make something up, but I am posting here so I can find this thread again because besides heated mirors and seats, I really want cruse
Old Oct 24, 2005 | 03:27 PM
CoffeeBean's Avatar
I have the dealer installed cruise control in my xA. It works better than the factory cruise control in my Subaru Forester....
I definitely see the savings in mileage on long road trips...
I also enjoy not having to sit on a pedal for more than a couple hundred miles....
Old Oct 25, 2005 | 11:26 PM
eXActly's Avatar
I put the rostra in myself. Got it for $185 - definitely worth it.
Old Oct 26, 2005 | 07:37 PM
EExA's Avatar
The 06' have a differnt tach or speed sense wire in the harness. I don't know exactly what one is different but the 06 has a different ECM and color wiring. I'll be putting a cruise in our xA before Christmas as I'm finally taking it on a road trip to Vegas and refuse to foot it all the way.
Sgtfluffy16
Regional - Northeast
Jul 28, 2021 10:32 PM
BlingSlade
Oct 19, 2016 12:39 AM
oldcodger
Scion tC 1G ICE & Interior
Dec 24, 2015 09:46 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
BlingSlade
Sep 5, 2015 08:52 AM
