just got new CC short shifter pic. they added spacers
Old Oct 19, 2005 | 02:39 PM
Batjew's Avatar
Default just got new CC short shifter pic. they added spacers
and it came with no instructions. oh well. I'm gonna call and check, but basically the shifter comes with 4 purple spacers, im assuming they're for lifting the shifter housing to a normal level. and they include an aluminum **** now.
Old Oct 19, 2005 | 03:15 PM
maximus96's Avatar
the purple things are used to replace the rubber bushings in the shifter cage. i used them and the shifting felt great. look up the instructions for installing the TWM shifter in the tech articles. the steps are exactly the same. the
Old Oct 19, 2005 | 03:26 PM
Batjew's Avatar
no luck finding the article.
Old Oct 19, 2005 | 06:31 PM
jmiller20874's Avatar
Here ya go:
https://www.scionlife.com/forums/viewtopic.php?t=36452
Old Oct 19, 2005 | 09:36 PM
Batjew's Avatar
installed it without the spacers, i did call CC and they said it's just to raise the shifter housing to stock, but it's optional. shifts are much nicer now but this thing is stiff, probably just needs more lube, would vaseline be safe to use?
Old Oct 19, 2005 | 09:41 PM
The_Instigator's Avatar
Use some white lithium grease if you can...it will last a long time and give plenty of lubrication. It should loosen up the more you use it..
Old Oct 19, 2005 | 09:43 PM
STAT's Avatar
KY is so much better , but for the shifter, couldn't tell ya, I have the same thing it felt really stiff and after a few weeks and a bunch of white lithium spray on lube it is closer to being stock smothness, I'm thinking about makeing a weighted shift ****, should help.
Old Oct 19, 2005 | 10:21 PM
Batjew's Avatar
i got a TRD **** to complament the shifter. im assuming lithium grease can be found at autozone?
Old Oct 19, 2005 | 10:24 PM
Sure can.
Old Oct 19, 2005 | 11:37 PM
Batjew's Avatar
got some at pepboys.
Old Oct 20, 2005 | 12:17 AM
jjos1's Avatar
I got some at Home Depot. I put the spacers in just make sure you take out the rubber part if you put them in. You should put them in they make a big difference.
Old Oct 20, 2005 | 01:38 AM
Batjew's Avatar
i prefer the shorter shifter, getting used to the stiffness though.....
Old Oct 20, 2005 | 02:17 AM
STAT's Avatar
one thing about the grease, it goes on really liquidy and then it thickens up, but leave your windows open, the fumes are crazy bad.
Old Oct 20, 2005 | 02:51 AM
Batjew's Avatar
uh, i had no problem with the grease
Old Oct 20, 2005 | 02:52 AM
Yeah...what kind of grease did you use?
Old Oct 20, 2005 | 02:54 AM
Batjew's Avatar
mulitpurpose lithium grease
Old Oct 20, 2005 | 02:59 AM
No..I meant STAT...what did he use that smelled so bad?
Old Oct 20, 2005 | 06:17 AM
87na's Avatar
nice write-up
Old Oct 20, 2005 | 08:15 AM
FLINT's Avatar
Old Oct 20, 2005 | 11:03 AM
superbill's Avatar
it loosens up over time ? put more grease on it?
i hope its better than my b&M shifter! cause ive had it on for 7 months and its still stiff as hell!
plus i have those same exact spacers (looks identical to those except mine were blue) and after i put on my megan exhaust the vibration made those spacers rattle!
its just metal to metal no rubber between, so i would not put them in.
in my opinion those short shift kits suck, they make a already notchy shifter notchier, yeah the throws are alot shorter, but less smooth , its a trade off that i for one dont think is worth it
i would like to see someone make a different linkage on our tranny to give it more leverage, but so far no one has addressed this (aftermarket wise), but i think that would be better rather than just having a different bend on a shorter stick!
