Flip Down Install
Old Oct 20, 2005 | 05:18 AM
Slammed04xb's Avatar
Default Flip Down Install
hey everyone couldnt find much info on a flip down tv install, does anyone have any info or ideas on how to secure this up on the roof? any info is greatly appreciated
Old Oct 20, 2005 | 03:06 PM
tbone587's Avatar
basically your going to have to take the headliner down. Then secure a piece of plywood to the rails running across, put the headliner back on, and then screw the flipdown to the wood
Old Oct 20, 2005 | 04:28 PM
edlin's Avatar
Sometimes you can get lucky and if your flipdown is small/light enough, you can use the existing dome light screwholes.
Old Oct 20, 2005 | 06:34 PM
Grime's Avatar
how would you power it? tap the dome light?
Old Oct 20, 2005 | 10:01 PM
edlin's Avatar
Dome light has acc power so you could use that since the dropdowns dont typically use a lot of power. I would be using a relay switched power from my dvd unit so the screen turns on when the dvd turns on, not the car.
Old Oct 21, 2005 | 03:50 AM
Grime's Avatar
okay then I have an off-topic question: I am installing two visor monitors tomorrow, and I need to power them. The power wires look like they will reach down into the dash, and I wanna tap into something there. I probably shouldn't tap into the cigarette lighter, since my LEDs are tapped into that, right? Any other tapping suggestions?
Old Oct 21, 2005 | 05:28 AM
edlin's Avatar
those monitors only pull about 1 amp together, check the box for exact.. your acc circuit is 15 amps. Your cathodes probably use 1 amp for all of em.
GoodVibes
10
Sep 2, 2015 01:22 PM
SuBSiN
Mar 13, 2015 04:02 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
