whats better
Old Oct 20, 2005 | 11:16 PM
jct's Avatar
jct
Default whats better
for rain driving besides tires
solid rotors or slotted rotors???
Old Oct 21, 2005 | 03:37 AM
Tomas's Avatar
Admin Emeritus
Johnny, I don't really think that slotted/solid makes all that much diff in wet conditions - both self-dry in next to no time...
The slotted just cool better in extreme conditions.
"Just my opinion..."
Old Oct 21, 2005 | 03:50 AM
Prototype_xB's Avatar
Parachutes
Old Oct 21, 2005 | 03:52 AM
Rotor fins do the majority of cooling, drills and slots help pocket gases, etc. created from braking and of course provide added cooling.
*edit*--> depending on machining techniques for drilled and slotted rotors, they have shorter life, ex.-> wear, cut, and warp quicker.
Stick with the stockers
Old Oct 21, 2005 | 11:59 AM
jct's Avatar
jct
well thanks that helps alot on save me more money major plus keeping my pockets heavier
Old Oct 21, 2005 | 10:08 PM
DarkBoxJr's Avatar
Drilled/slotted rotors just look better. They don't do anything for performance because your brake pads aren't made from asbestos anymore.
Old Oct 21, 2005 | 10:34 PM
jct's Avatar
jct
what about ceramic brake pads and shoes???
besides able to take the heat better and producing less brake dust
Old Oct 21, 2005 | 10:57 PM
Tomas's Avatar
Admin Emeritus
Higher tech brake pads such as the newer ceramics can be a plus - and in fact are even used on the stock Scions.
Just don't use 'racing pads' that require high heats to even be effective - they are a very poor choice for a daily driver...They resist fade in heavy use, but need to get close to 'red hot' before they are happy.
Old Oct 21, 2005 | 11:10 PM
deviousXA's Avatar
ScionERA
Im runnin SATISFIED PRO CERAMIC pads.....great grip over OEM pads and they have a split pad design for further heat disipation they are like 60 some odd bucks off of satisfieds site but i was able to pick up a set for $36.00
Old Oct 22, 2005 | 02:59 AM
Want pads and shoes that'll stop quicker---> look at the composition. The more metals, the higher the performance. Although the catch is quicker rotor wear and scarring.
Old Oct 22, 2005 | 04:38 AM
Emfdiablo's Avatar
i like the parachute idea, i say go with two of them...ohh ohh the ones that open in an X pattern...ha ha ha
seriously, these cars have decent stopping power, specially when they dont go that fast to begin with, but if you want better stopping power, go with stainless steel brake lines (these will help in brake fade and pressure) along with the ceramic pads devious was talikng about
Old Oct 22, 2005 | 06:16 AM
Boxer_Rebellion's Avatar
Get the euro RS rear discs
Old Oct 22, 2005 | 07:52 PM
JSosa's Avatar
brakes are not affected by wet or dry because with just one slight press on those brakes they will dry QUICK! But as everyone is saying you changs to more aggresive pads you will have added rotor wear and scaring that may lead to warping. Since i dont care about how fast my Xa goes i just care how it turns and brakes i put the A&Z brakes on my Xa and DAM!!! I got he rear disc conversion, orignially sold for the echo, but work great with the Xa and the front rotors. This kit comes with rotors, calipers, bracktes, pads and lines. Whatelse do you need. You want to stop I HIGHLY recommend this setup. Its scary how well my Xa stops.
Old Oct 22, 2005 | 10:03 PM
gnar-de-gwar's Avatar
rear brakes! egad! where and how much?
Old Oct 27, 2005 | 12:22 AM
elusivedragon's Avatar
i had upgraded brake pads on my old corolla and liked it, did notice a difference...also had a lot less brake dust all over my front wheels....in fact never had ANY so that is why i like em
going to do that for my new xb, thinking about brake lines too but not sure how hard that would be to install/swap
