View Poll Results: How many round fogs should I put behind my lower grille?
30.00%
15.00%
None it will look stupid
55.00%
Voters: 20. You may not vote on this poll
Fogs behind lower grille
Old Oct 23, 2005 | 10:24 AM
English's Avatar
Default Fogs behind lower grille
I have had this idea to put some round (traditonal style) yellow fogs behind the lower grille of the tc..2 or 4(rally style) I'm not sure yet. I can't do it yet cause I've been in Thailand for the last 3 weeks but what do you guys think about the feasability of this project?
I'm not sure yet how to mount the fogs, what ones will fit and what it will look like.
Any comments/suggestions?
-English
Old Oct 23, 2005 | 01:09 PM
Neothin's Avatar
I asked about the feasability of putting fogs behind the lower grill a while back. The response that I got was that the mesh grill disperses the light everywhere and doesn't really provide any extra illumination. They said it would be better to cut holes in the grill for the lights to sit flush in so that they're not behind the grill.
Old Oct 23, 2005 | 01:16 PM
bblhed's Avatar
It's your car, I say if you want to do it go for it. Judgeing by the number of people that say it will not look good this will give you a unique mod that few people have.
Old Oct 23, 2005 | 02:39 PM
ack154's Avatar
Or you could do THREE and be really different.
Moved to DC.
Old Oct 23, 2005 | 03:35 PM
English's Avatar
Moved to DC.
I actually thought about 5....but I'm not sure if that many would fit given the limited diameter
Old Oct 23, 2005 | 03:36 PM
chizzzle's Avatar
well i have stock fogs and i recently put over billet grille insert over them a few weeks ago. the light output is definently affected. lets just say that if you really like to use your fogs that you you should prolly cut holes
Old Oct 24, 2005 | 03:16 AM
English's Avatar
Well I'm still gonna do it when I get back to Atlanta, probably use 4 4" (if they fit) yellow lense round fogs..
I'll keep everyone posted with pics and what not when I get started on it
Old Oct 24, 2005 | 03:37 AM
Fhe1079's Avatar
Well it may sound cool to have them behind the grill. But also think about the heat from the bulbs... will it melt the grill or warp it in any way... Testing is better when you know more about it.
Old Oct 24, 2005 | 04:04 AM
falcon9094's Avatar
I have the factory fog lights behind a grill craft grill and it looks good
Old Oct 24, 2005 | 05:51 AM
English's Avatar
Any chance of some pics from you falcon9094 and chizzzle ?
Old Oct 24, 2005 | 06:19 AM
gwtc's Avatar
I used to have some behind the upper grill, I had a custom mesh grill there thou.
Old Oct 24, 2005 | 06:24 AM
apexjr's Avatar
How did you mount them? I tried a number of different ways to get the small Hella Micro DE's behind the side inlets and I just couldnt make them work and be solidly mounted so they wouldnt move. Props to the people who got fogs in the side inlets, it's not easy... at least with the lights I tried.
As for putting them behind, you light will be halfed if not more. I put a light behind there just to see what it would look like and it got very dim.
Old Oct 24, 2005 | 06:49 AM
gwtc's Avatar
here's the post:
https://www.scionlife.com/forums/vie...er=asc&start=0
here's where I used to have them before I installed them in the upper grill:
Here's a night pic:
p.s. not trying to hijack anybodies post .
Old Oct 24, 2005 | 07:17 AM
English's Avatar
Hey don't worry about it you're not hijacking I'm not sensitive unlike some members on sl...
Anyways I read through the thread where you did the how to- I have a feeling that it will help me alot. I think in some of the pictures from inside the space of the lower grille I saw a crossmember which I can bolt the fogs too, which I never would have known was there unless I jacked up the car myself - Thanks. Can you confirm if it's metal or not?
I'm checking out sciongirls.com right now cause some girl in your post said she saw a girl on there who had fogs on the lower grille- thanks again for your help gwtc
Old Oct 24, 2005 | 08:14 PM
gwtc's Avatar
Thanks, glad I could help, but not sure which part you are talking about, can you post the pic and point out the part for me? thanks.
Old Oct 25, 2005 | 12:30 AM
falcon9094's Avatar
Old Oct 25, 2005 | 12:50 AM
TrappedInABox's Avatar
i have yellow fogs behind my lower grill on my box and it shines just fine. i have pics but they kinda suck...
Old Oct 25, 2005 | 12:58 AM
OooThatsSharp's Avatar
Before you start throwing extra lights on your car, check your local laws. Here in Ohio, you are only allowed to have 3 extra lights on the front of your car, so by law, if you have those led windshield washer lights on as well as your fog lights, the police can pull you over and give you a ticket. I don't want to rain on your parade, I just want to help you avoid some possible hassle.
Old Oct 26, 2005 | 01:31 AM
English's Avatar
Originally Posted by falcon9094
Looks sweet- any idea about the diameter of the stock fogs? jw I just got back to Atlanta (27hours traveling ) so I'm going to start getting everything together for this mod tomorrow
Old Oct 26, 2005 | 01:47 AM
English's Avatar
Just found out something interesting-
I checked out the install guide for the factory fogs and found out the wiring harness is basically all there and all you have to do is add some wires up front, one to ground and to the fogs, and then add a relay and switch inside the cabin to the existing fog light harness there and you're set! No need to run any wires through the firewall.
here's the link http://www.trdsparks.com/install/PT413-21050inst.pdf
airmankevin1
Feb 14, 2018 01:23 PM
bluemex
Oct 14, 2015 03:29 PM
SloTC1
Apr 2, 2015 07:11 PM
Pirate183
Nov 29, 2014 07:37 PM
randode
9
Oct 25, 2003 04:58 AM
