Grill Idea
Old Oct 26, 2005 | 07:19 AM
Guamsilverbox671's Avatar
Default Grill Idea
I was going to paint by grill black, so I was messing areound with this picture. And thought, would it be cool to have the grill match the lower bumper grill? :D
Old Oct 26, 2005 | 08:11 AM
Tomas's Avatar
Admin Emeritus
That would look nice, but I haven't seen any material like that available. I'm just going with the OEM grill in black (and some sort of lighted custom emblem).
Old Oct 26, 2005 | 12:09 PM
Max's Avatar
Max
Moved to DC.
Old Oct 26, 2005 | 12:28 PM
Newtmaker's Avatar
Hey, Guamsilverbox671, where was that pic taken? I spent a total of almost 8 years on Guam when in the Navy. I really liked it over there. Still communicate with lots of folks there.
Hafa Da!!
Walt
Old Oct 26, 2005 | 01:17 PM
jamesgang's Avatar
Git-R-Done! Nice wheels too.
Old Oct 26, 2005 | 01:41 PM
dudehitt's Avatar
I like it, but like Tomas said, it would not be easy. I always did like the lower grill honeycombs.
Old Oct 26, 2005 | 03:04 PM
stick_1NZ's Avatar
go black and also drop that burakkubokkusu (bB).
Old Oct 26, 2005 | 11:57 PM
OneBadBox's Avatar
How in the heck does painting a grill of an xB change the drag coefficient?
Old Oct 27, 2005 | 12:06 AM
dgHotLava's Avatar
if you look again, the grill is not painted. it is different.
this forum is not only for things that alter the drag co, but is a fun name used to describe all aspects of the external apearance.
grills paint, CF hoods or wings, winodw vent shades, decals....ie almost anything outside is related to drag co.
got it???
Old Oct 27, 2005 | 12:09 AM
dgHotLava's Avatar
ps. i don't care for that grill idea. too many 'holes' to clean bugs out of...
Old Oct 27, 2005 | 12:22 AM
Tomas's Avatar
Admin Emeritus
I agree about the bug cleaning - that's one reason I don't even like wheels with a bunch of spokes - cleaning.
I disagree with the name of this forum - "Drag Coefficient" does not tell the average poster as much as "Exterior" would...
But that's an old complaint. I'll leave it alone.
In fact, I even like the bB OD grill better than the stock grill just because it is easier to clean...
As far as just the LOOKS of the hex grill idea that started this - it does look good to me.
Old Oct 27, 2005 | 12:33 AM
Max's Avatar
Max
I don't think that more cool air circulating around the engine compartment would be a bad thing, but the stock grille is solid, where this would obviously not be. There would be more bugs and dirt to clean up.
Old Oct 27, 2005 | 12:53 AM
Tomas's Avatar
Admin Emeritus
Max, as a fellow engineer I would srongly suggest that the back of the top grill be blocked off - yes, it may allow more airflow (and dirt) in the engine compartment, but the current design is better at assuring adequate airflow through the radiators...
Opening up the top grill on the bB/xB seems to reduce the flow through the radiators due to the higher inflow without their being a commensurate increase in outflow area.
Old Oct 27, 2005 | 12:56 AM
dgHotLava's Avatar
yes, too much cooling can be a problem.
block off the top grill.
Old Oct 27, 2005 | 01:09 AM
Max's Avatar
Max
Thanks, I wasn't sure how far up the radiator/evaporator reached.
Nice overcomplicated engineer talk, btw.
Old Oct 27, 2005 | 01:16 AM
Tomas's Avatar
Admin Emeritus
Heheheheheh... You should hear me when I really get going.
Maybe this is better, though:
Opening up the top grill to airflow increases the airpressure in the engine compartment, reducing the airflow through the radiators, which only get air from the bottom two grills.
Naw, that doesn't do it either. Hmmmmmm...
Opening up the top grill to airflow lets the air bypass the radiators.
OK, that will have to do.
Old Oct 27, 2005 | 10:24 AM
dgHotLava's Avatar
take your pills Tomas,,,,
now inhale.......and exhale....
Old Oct 27, 2005 | 02:36 PM
Hey thanks for the comments. I'm still thinking of painting it black, and I just looked at another thread were I saw a TCM xb w/ a black griil; looks cool. The honey comb grill was just an idea, thought it look cool to see what the respond would be
Although if this mod were to be a reality, bug cleaning would definetly be a problem
Hey Newtmaker, this pic was taken in my front yard, were I live in Wusstig Road, aprox. 4 miles away from Anderson Airforce Base.
stick_NZ1, yes I do agree that it needs to dropped. Plans for that are ahead but as usaul, mod like this needs some fund which I currently don't have at this time
Old Oct 27, 2005 | 02:50 PM
dudehitt's Avatar
IF you could find material to make the honeycomb top grill you would just need to put a solid plate behind it. Preferably something that was easy to remove because the bug mess would be impossible to clean down at the bottom of the holes.
Old Oct 27, 2005 | 03:01 PM
Max's Avatar
Max
If you're gonna paint, check out the thread below. The results are hot!
https://www.scionlife.com/forums/viewtopic.php?t=77152
