Intake Problem
Old Oct 27, 2005 | 01:12 AM
th3s3x's Avatar
Default Intake Problem
Hey guys.. got a little problem, and can't figure out what to do.
I've had my Weapon R intake for about 4 months now, never any problems. Now all of the sudden my CEL is on and my car is idling weird... ex: sometimes after putting it into neutral it will drop below 500 and come back up to about 1000 but never stay steady, it sorta bounces around between 700 and 1500. Every now and then when I have started it, it's actually stalled.
Now I took the whole thing off, re-installed it, made sure all the seals were tight. I reset the ECU by pulling the fuse trick. It seems to be running a little better, but the CEL is still on.
Anyone have any ideas?
Thanks!!
Old Oct 27, 2005 | 02:02 AM
Metro273's Avatar
Don't know if this is your problem BUT most likely it will be. I work at a Nissan dealership and we get alot of guys come in with Sentra Spec Vs with CAIs. They all usually have the same symptoms as you do: Runs rough or stalls, CEL "on" or lack of power. The oil on the filter is sticking to the wire thats inside of the MAF sensor causing the your problems.
Old Oct 27, 2005 | 02:40 AM
Jarrod123's Avatar
after reading a number of other posts that's what it does seem like it could be. does anyone one know if there is a way to prevent this? is this something that will happen to everyone?
Old Oct 27, 2005 | 02:41 AM
Jarrod123's Avatar
if that is your problem just make sure you switch it back to stock before taking it in to the dealer.
Marganne
Apr 3, 2015 06:52 PM
Sumtallguy
Mar 24, 2015 04:55 AM
Scionxa180
Mar 13, 2015 04:39 AM
AxRxP
Jan 25, 2015 08:40 PM
hotroddelux
Dec 3, 2014 11:33 PM
