DVD playing while car is in drive.
Old Oct 28, 2005 | 04:00 AM
GreenDog's Avatar
Default DVD playing while car is in drive.
I am getting my indash dvd player installed tomorrow. I have a feeling that the people who are installing it are going to make it so dvds cant be played while the car is in drive. How can I disable this? I have the AXV-4024
Old Oct 28, 2005 | 04:26 AM
DJ_X_Trodinaire's Avatar
they wont hook it up because they dont want to get blamed or fined.
Old Oct 28, 2005 | 04:27 AM
INSIDEOUT's Avatar
who is it made by? You will need to ground the wire or put power to it or you might be screwed if it has a gyro cause you cant
Old Oct 28, 2005 | 04:45 AM
GreenDog's Avatar
I have the Ecplise AVX-2404
Old Oct 28, 2005 | 05:02 AM
yellowxboy's Avatar
idunno if this helps or not but i have a jensen dvd player in my 94celica (installed from circuit city) and the only way for it to play is when the car is in park ... but the installer told me that i can bypass it by just having the ebrake on one click. he said that it doesnt ruin the ebrake. i've driven w/ the indash for 6 months and no problems. (i have an auto btw though) hope that kinda helps?
Old Oct 28, 2005 | 05:51 AM
SimplifiedScion's Avatar
if it anything like my alpine all i did when i installed it was replace the ebrake with a toggle switch. by that i mean running the wire to a toggle switch and from the toggle switch to a ground.
Old Oct 28, 2005 | 06:01 AM
ChicagosFinest's Avatar
OhioScions
alot of the time installers (at least the one's I know) ground the parking brake wire because they're lazy.. but shhhhh!
Old Oct 28, 2005 | 04:11 PM
INSIDEOUT's Avatar
If you need help with it holler.. It is easy..... 918-698-0189
Old Oct 28, 2005 | 04:13 PM
Fredy's Avatar
I sent you a PM about the shop
Old Oct 28, 2005 | 04:30 PM
ElChupacabra's Avatar
Yeah I wired my parking brake wire right into the ground wire right next to it. Works like a charm but you didnt hear that from me and I didnt hear it from the guy at Circuit City...
Old Oct 28, 2005 | 04:57 PM
Macster's Avatar
Good to know when I get my D1...
Old Oct 28, 2005 | 06:44 PM
Romanova's Avatar
Just so you know, that is easy PC for a cop to stop you if you are driving around at night with a DVD going... just a heads up.
Old Oct 28, 2005 | 07:15 PM
yellowxboy's Avatar
*pushes open/close button on jensen unit* by the time they pull me over.. i'd have it closed or switch it back to radio mode that displays on the 7" screen :p
Old Oct 28, 2005 | 09:06 PM
violent_b's Avatar
the D1 is a little different. takes more than grounding the brake wire. stupid Pioneer.
Old Oct 28, 2005 | 09:27 PM
spectra_blue's Avatar
Yea, most audio places won't COMPLETELY hook up a bypass switch for you, cause it will cause them to get into trouble if you were to be ticketed for it. But, the solution is quite simple... Be forewarned that this is the way to do it and I cannot be held reliable for any actions you do from using it.
What you need:
Toggle switch
Extra wire (14 gauge or any other close in size)
What to do:
Find the brake and ground wires coming from the harness of your headunit. Wrap a wire onto the ground of the switch and tap that one into the ground wire on your wiring harness. Then, wrap a separate wire from the switch accessory (or whatever it is labeled on the switch you have, some are different. It'll be the opposite pole of 12V.) and tap that wire into your brake wire in the harness.
Start your vehicle up. Flip the switch once, then back again, then you should be all setup for movies down the road. What the swtich does is grounds out the headunit and makes it think the brake had been set. You'll have to flip the switch everytime you turn off your car.
Again, its YOUR OWN decision to do this. I only supplied the information on HOW TO do it. But, good luck and enjoy the film.
Old Oct 28, 2005 | 10:02 PM
RJonesy's Avatar
I have a kenwood DVT815 dvd flip out and I just straight-up asked the guy installing it to wire it so that it would work when I'm driving and he didn't say anything. I just had to re-tint my back window to make it pretty much blacked out so you can't see when I have a movie going. You will be fine as long as a cop doesn't just rollup right next to you. I've been pulled over for speeding and I had enough time to put the screen away and close the radio door.
O5_TRD_tC
Feb 18, 2015 09:01 PM
stayintrucha
Scion tC 2G ICE & Interior
Dec 18, 2014 04:36 PM
lunchbx05
Dec 11, 2014 06:13 PM
tC_Normo
Oct 22, 2003 07:20 PM
