Xb Questions on Component Speakers + Amp installation
I finally got my xB and I'm super-happy with it. The only things I don't like are the tiny mirror and the fact that I get speaker distortion when I turn up the volume. I've installed head units and speakers before but never amps, but this time I want to do a pretty nice setup for the xB. I've been doing a lot of research and searches here but I'm still unclear on a few points, but here's my initial idea. I want to keep the stock Pioneer and I don't need a lot of bass power, just very clear audio.
1. Get a good set of component speakers, looking at the Polk db6500s, to install in the door and dash
2. get a small amp to power the speakers and MAYBE add a sub later on, if so I would want it under a seat.
3. Get decent coaxials for the rear
Here are some questions I have. Let's say I get a four-channel amp. I would use a line output converter to connect the head unit to the amp, then connect one channel of each amp to the component crossover. That gives me two channels left which I just leave unconnected for now in case I want to install a sub. How will the headunit treat this set-up? Will the bass and treble adjustments still work? Is there any advantage in putting the component crossovers in an accessible place? I don't quite understand ohms, but do I need to, or is everything in this setup 4 ohms? If I put the amp under the seat where is the best place to ground it? Can I reuse the speaker wire that runs from the headunit to the door or do I have to run new wire? I would greatly appreciate any advice. I plan on buying most stuff from Crutchfield and installing it myself.[/code]
Hi, glad to hear you have an XB, try Chris AKA (mandos) hear on Scion Life, he works for a SL sponser elemental designs, check out there website at www.elementaldesigns.com for some nice comp speakers and amps at great prices. I think you are headed in the right direction at what you want to do, also Crutchfield also has nice products.
Good Luck
John
Good Luck
John
corbmonster
Jan 24, 2015 06:13 PM
TheRedBox
31
Dec 2, 2003 04:53 PM
