smoked headlights?
Old Nov 3, 2005 | 06:29 AM
rwf's Avatar
rwf
Default smoked headlights?
has anyone tried smoking out thier headlights lightly with nightshades? how does it look? how much does it effect light output of hids? neone have pics?
Old Nov 6, 2005 | 03:37 PM
Voltairecim's Avatar
Bump. Because i am curious as well.
Old Nov 6, 2005 | 04:16 PM
Serialk1llr's Avatar
OhioScions
rockblocker has vinyl headlight overlays. Search for it ;)
Old Nov 6, 2005 | 09:44 PM
rwf's Avatar
rwf
i kno ppl have vinyl headlights.. but what about nite-shades spray?
Old Nov 6, 2005 | 10:16 PM
KINGxOFxSKA's Avatar
Unique Scionikz
niteshades has a a lil red mixed with the black.... so it might come out a lil purple if you do it on the headlights. it works on taillights because those are already red. hope that helps.
Old Nov 7, 2005 | 02:15 AM
OhioScions
jost smoked mine, they look hot. Thanks KingofSka
Old Nov 7, 2005 | 04:01 AM
rwf's Avatar
rwf
smoked ur tails? or headlights? if headlights, can u post some pics?
Old Nov 7, 2005 | 06:18 AM
dp-_-'s Avatar
headlightarmor also has them. Nightshades can also be extremely dark. Like ska's tails....that's assuming you apply as many coats as he has. Considering that they're used to actually see stuff, I wouldn't suggest it.
Then again, I have no experience with that stuff, so why am I even speaking........
Old Nov 7, 2005 | 12:39 PM
OhioScions
sorry, tailes only. Not sure i'd wanna do headlights.
Old Nov 8, 2005 | 09:03 PM
Blue_Batmobile's Avatar
See my Gallery below
Bat™
Old Nov 9, 2005 | 06:07 PM
OhioScions
Hey bat, are you in a Sales job by any chance? ;) You're really thorough with the follow-ups
*eddited becuz I kan't speel!*
Old Nov 9, 2005 | 07:01 PM
TheScionicMan's Avatar
I've got ClearGuard smoked overlays. If I get popped, I can peel them off. What are you going to do if they're painted? There's a light decrease but since my driving is 99% freeway or city, it's not an issue. When I went to my parent's out in the boonies, it was noticable for sure. But dang, it looks good, don't it?
Old Nov 9, 2005 | 07:28 PM
rwf's Avatar
rwf
looks very nice~. But to answer ur question, the paint can be removed easily i heard.
Old Nov 10, 2005 | 02:11 PM
RockBlocker's Avatar
The problem with using nightshades is this.
It is very hard to get it even and smooth. Plus you ahve to sand them afterwards and then clear and then sand again to get them to come out right. You dont know for sure if they are going to be too dark or too light until you are totally done.
Then for removal you have to use a strong cleaner (ie laquer thinner) or something like that. This can cause your lights to dry out and crack the plastics lense itself which means you are out a set of new headlights.
There is a big risk and uncertainty when using night shades. Sure the product costs like $8.00 and seems like the cheap way to go, but the side effects can cost a lot more.
We offer smoked light film that is actaully a light pteoction film that prevents rocks, dirt, sand and other road going debris from damaging the light while adding color.
If we can heelp with anything else please let us know. Oh yeah, our kit installs in 10 minutes.
Hope this helps answer more of your question
Old Nov 10, 2005 | 02:20 PM
rwf's Avatar
rwf
sighh.. that looks nice.. but last time i tried putting on overlays just for my side lights and failed miserably.. dont think i can do it for hte headlights..
Old Nov 10, 2005 | 08:19 PM
ScionDad's Avatar
Toastbox sent me some overlays that I failed really bad at putting on. I couldn't get rid of the wrinkles at the lense bends and a few bubbles would not go away.
I got the night shade and wow is that the best stuff to use. No need to remove the tails...just tape good (I used that blue painters tape). Then taped newspaper to that and off I went.
I put on a light layer, waited 10 min, light layer, 10 min, etc. I kept going until It was dark enough . I waited 1/2 hour then started doing the same thing with clear coat. light coat and wait 10 min...I did light coat 3 times then applied a medium "wet" last coat. Waited 1/2 hour and took off all the tape and newspaper.
WOW...not a single run.
2 days later I used light rubbing compound and it looks perfect.
Old Nov 11, 2005 | 12:52 AM
dp-_-'s Avatar
If you look at the thread that I started regarding my smoked tails, I couldn't get about 20 wrinkles out....but hey came out themselves
I also left a MASSIVE bubble that still had soapy water underneath it that I didn't notice. I washed my car like a month later and they all disappeared. I LOVE my tails
Old Nov 12, 2005 | 01:29 AM
Unique Scionikz
there is no problem with niteshades sorry. it comes out smooth and clean. yes it requires more work by wetsanding and time but the results are amazing and will outlast overlays any day. i've seen overlays time and time again peel, fade, wrinkle, and look gross over periods of time.
Old Nov 12, 2005 | 02:16 AM
But have you ever seen someone remove it?
Old Nov 12, 2005 | 02:33 AM
jonnyHKboi's Avatar
if you do use the spray, don't forget that "wet" coat....i've seen some cars w/o it and the smoked lights come out with a dull coat which looks wack.
