Wattage and Sylvannia silverstars
Old Nov 7, 2005 | 11:59 PM
fm_tc_cruizer's Avatar
Default Wattage and Sylvannia silverstars
I recently put some Sylvannia Silverstar low beams on my tc. I got them from the nearest Discount Auto. Anyway, the box said that the lights were 55 watts. However from reading some posts around here about the luminics, I hear that just the 5 watts over the standard 50 watts is likely to cause electrical problems (harness melting or possibly electrical fire). I've seen a lot of people with this mod. So either they don't care about it or there's a 50 watt Silverstar version somewhere out there. I have yet to find 9006 Silverstars that are 50 watts. thnx. So lemme know if i should worry or not.
Old Nov 8, 2005 | 12:09 AM
ChicagosFinest's Avatar
OhioScions
I have 55w Silverstars.. Had them since I got the car.. not a problem..
Old Nov 8, 2005 | 02:30 AM
PrivateTucker's Avatar
My silverstars I believe say 51 on the back of them.
Edit: I just went outside, pulled one out, and it says 51W on the back of it.
I bought them at Walmart. they are the 9006's.
Old Nov 8, 2005 | 03:08 AM
Garage1217's Avatar
I have both the 9006 and 9005's. Had them since 80 miles on the car. Nothing but awsome white clear light!
Old Nov 8, 2005 | 03:56 AM
panasoanic's Avatar
There are several standards for rating automotive light bulbs. Some require the power to be measured at 12.8 Volts, others at 12.0 Volts (and I believe 13.2 Volts is used as well). HB4 / 9006 type bulbs are rated 55 Watts at 12.8 Volt, and 51 Watts at 12.0 Volts. Same bulb just measured at two different voltages.
And in case someone finds that the numbers do not jive with Ohm's law, when you run the bulb at 12 Volts rather than 12.8 Volts, it will run a tad cooler, and the resistance of the filament will be a little less. The hotter the filament, the higher its resistance.
Old Nov 8, 2005 | 05:13 AM
Hyghgynx's Avatar
SilverStars will not cause electrical problems unless you touch the bulbs with your bare hands! I've had my SilverStars in for almost a year now with no problems. You should be aight.
Old Nov 8, 2005 | 05:19 AM
Garage1217's Avatar
Touching them will cause NO electrical problems. It will however cause the lifespan of the bulb to be seriously reduced.
Old Nov 8, 2005 | 05:30 AM
Hyghgynx's Avatar
^^Same difference. Jeez...Didn't know I had to be **** in here.
Old Nov 8, 2005 | 05:31 AM
Garage1217's Avatar
hmm... saying touching a bulb causes "electrical problems" guess you could view a burnt bulb as an electrical problem... *LOL*
Davestoaster
Jul 28, 2005 12:37 AM
Suldal
Nov 21, 2004 05:35 PM
IBNXB
25
Nov 4, 2004 05:30 PM
Dakine
Oct 9, 2004 11:38 PM
Dakine
Sep 24, 2004 03:12 AM
