Check out this Air to Water Kit - Never seen this kind
What are your thoughts on this kit? Fitting this to the ZPI stage 0 would be pretty easy to do.
http://cgi.ebay.com/ebaymotors/PWR-A...spagenameZWDVW
Originally Posted by Stu_Gotti
Hmm.. over my head... What does this thing do?
Air to water is much more efficient and not contigent on the outside air nearly as much. Also, sitting in traffic...it still cools the air. Not to mention the plumbing for this is soooo much easier than FMIC to work with
PWR makes one of the best cores out there. While that does seem a bit pricey, i know that the i've seen it slightly cheaper, it is a great idea. throw it inline from turbo, weld BOV fitting on there and boom done. run 2 AN lines to the heat exhanger with the pump in line and boom, instant cooling. I wouldn't use too much coolant in the mix, just distilded water with water wetter, then maybe drop in 20% antifreeze during freezing season.
here' my only source for help: call Mike @ 714.688.0222
He's at Laskey Racing. Earl Laskey used to sell PWR A/W intercoolers so i'm sure they still may have a connection. Just an FYI, they are great people. If you want to really talk tech, I can shoot you earl's number, but he can get intense on you.
us honda owners always have our eyes out for good prices. FYI Earl is one of the big names in high performance hondas, AKA those cars that make 800+whp he's had his hand in a few of them. He's a huge in Quaife LSD, CP piston, Benson Sleeves, etc etc he has some damn good products and great prices.
I saw something along those lines a SEMA tC show car for the TRD S/C. I know Vortech make air to water coolers for there superchargers. It would be nice to see this on a s/c or turbo tC.
I've read nothing but good things about them and I like the idea of it really making the TC remain stock looking. No FMIC at all. Yes, there will be another small radiator and fan setup, but it's black and looks like a stock oil cooler. I only need 3 or so feet of charge pipe instead of 8 feet.
since you have the option, throw the BOV before the core, aka on the hot side. This way you don't tax the turbo to fill up the core just to bleed it out. plus you won't blow out chilled air.
be sure to post up picks, it should be easy to mount, just throw it in front, as you would a FMIC. infront of the AC condensor to let it get cold air. then you have the fan on it to help things out.
its the same reason you see some new people putting the BOV on the hotside of the FMIC instead of on the charge pipe. the purpose of the BOV is to vent air from the turbo so it doesn't get reverse waves. having the BOV closest to the turbo means quicker area to vent it.
hampton1100
May 28, 2015 07:32 AM
hotroddelux
Dec 3, 2014 11:33 PM
Strader
25
Jul 22, 2004 09:27 PM
