?? Drilling Carbon Fiber ??
Old Nov 11, 2005 | 10:14 PM
Rocket's Avatar
Default ?? Drilling Carbon Fiber ??
I need to drill my CF hood for washer nozzles. What is the best way to drill it. Mark it, Tape it, Drill It ??? Thanks
Old Nov 11, 2005 | 10:42 PM
dredge38's Avatar
i would like to know this to, im guessing youve got the right idea i would do the same but i would like to hear from somebody thats done it
Old Nov 11, 2005 | 11:03 PM
cierrecart's Avatar
Start with a nice new and sharp pilot bit (like 1/16th") and use high speed. Once you have that hole just go bigger and bigger till you're at the right size. Worked fine with my c/f hood when I did my hood pins.
Old Nov 11, 2005 | 11:18 PM
killerxromances's Avatar
^ ^ Thats what i did for my pins.
Just be sure there isn't a pre-existing cut out on the hood already. A lot of them come with pre-cut outs where you just pop it out and its the hole for the nossle. Just be sure you have to drill that you keep it straight and don't go crooked or off center.
Cya
Old Nov 13, 2005 | 01:02 PM
Rocket's Avatar
Thanks!
Old Nov 14, 2005 | 08:11 PM
ctruss's Avatar
The drills don't have to be nice and brand new (although that is better).
The correct way to drill out a material like that is to carefully drill a small pilot hole then use a reamer to make the hole bigger. Not only will a reamer not tear up the material, but it will give the holes a smooth finished cut when opened up to the correct size.
Old Nov 14, 2005 | 08:13 PM
ctruss's Avatar
Picture of a reamer, they are also available for use in drills.
Old Nov 14, 2005 | 09:35 PM
cierrecart's Avatar
I would never suggest using a hand tool on it. Slow speeds will eat up carbon fiber in a hot second. I actually uise a step drill, cut high speeds are still a must to keep them from chewing it all up.
Old Nov 15, 2005 | 12:19 AM
Rocket's Avatar
I drilled it with progressively (is that a word) larger dill bits. High Speed no problems! No tearing or chipping. They did a nice job!
Old Nov 15, 2005 | 04:17 PM
ctruss's Avatar
My picture above was mainly to illustrate what the bit would look like, I also advised using a drill.
Old Nov 16, 2005 | 07:00 PM
Orataro's Avatar
sIcKsCiOnS
Your best bet is to use a plexy bit. It's a drill bit pointed like the reamer as shown above. It's the best thing to use for plastics and fiberglass to prevent cracking when drilling thru.
prescottn
Sep 13, 2015 09:04 PM
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
StxArOne
Scion xA Aero & Exterior
Aug 29, 2015 03:29 PM
carid
Jul 14, 2015 01:10 PM
