?? Drilling Carbon Fiber ??
Start with a nice new and sharp pilot bit (like 1/16th") and use high speed. Once you have that hole just go bigger and bigger till you're at the right size. Worked fine with my c/f hood when I did my hood pins.
^ ^ Thats what i did for my pins.
Just be sure there isn't a pre-existing cut out on the hood already. A lot of them come with pre-cut outs where you just pop it out and its the hole for the nossle. Just be sure you have to drill that you keep it straight and don't go crooked or off center.
Cya
Cya
The drills don't have to be nice and brand new (although that is better).
The correct way to drill out a material like that is to carefully drill a small pilot hole then use a reamer to make the hole bigger. Not only will a reamer not tear up the material, but it will give the holes a smooth finished cut when opened up to the correct size.
Originally Posted by ctruss
Picture of a reamer, they are also available for use in drills.
I would never suggest using a hand tool on it. Slow speeds will eat up carbon fiber in a hot second. I actually uise a step drill, cut high speeds are still a must to keep them from chewing it all up.
sIcKsCiOnS
Your best bet is to use a plexy bit. It's a drill bit pointed like the reamer as shown above. It's the best thing to use for plastics and fiberglass to prevent cracking when drilling thru.
Subaru86
Scion FR-S ICE & Interior
Sep 10, 2015 08:11 AM
