Need help solving problems with LED change
Old Nov 13, 2005 | 01:33 PM
kevincon23's Avatar
Default Need help solving problems with LED change
So we've run into a little problem changing the LEDs in the dash and hvac in my '05 tC. I was wondering if anyone else had had this problem. After putting all of the new LEDs on the circuit boards we've tested and all of the LED's work properly, but after installation back into the dash and center consol none of the lights work. We're stumped. Has anyone else run into this problem and if so how did you resolve it.
Old Nov 13, 2005 | 01:57 PM
PrivateTucker's Avatar
did you try changing the leds around so current flows differently. I'm sure you know this, but LED's are direction specific.
Old Nov 13, 2005 | 02:40 PM
ack154's Avatar
Moved to Electrical.
Old Nov 13, 2005 | 09:56 PM
kevincon23's Avatar
we've tried that...any other suggestions????
Old Nov 13, 2005 | 10:11 PM
Correct package and voltage? What voltage are you putting across the Diode when you test it?
Also, when you install the diodes onto the PCB, is the brightness dial all the way up?
Old Nov 13, 2005 | 10:23 PM
Tomas's Avatar
Admin Emeritus
Yeah - the white and blue LEDs require a higher voltage to operate properly than do red or yellow in most cases. Some also require more current.
If the dropping resistors or other voltage/current control devices used to control the power to the original LEDs won't allow a high enough voltage or current for the new ones...
XB06
May 30, 2015 02:42 AM
RayScionXB
Regional - Pacific South
19
Mar 5, 2015 08:22 PM
RayScionXB
Regional - Everywhere Else
Mar 3, 2015 08:27 PM
mrsocks
Jan 20, 2015 01:29 PM
cid_mcdp
Jan 5, 2015 02:45 PM
