need installation
Old Nov 17, 2005 | 02:54 AM
JINeration's Avatar
Default need installation
i need help installin my 2 subs and amp onto my TC
i have a box but i dont have amps how do i install my 2 12"s onto my box they said i needed a special type of sealent to make it good but wut kind and do i just screw it in
how do i jus hook everything up these are the thing i have
http://i22.ebayimg.com/03/i/05/78/e2/36_1.JPG
that would b the amp
then i have these 2 subs
http://i18.ebayimg.com/02/i/05/54/11/cf_1.JPG
and a box of course but with out the amps inside so i need to know how to put them in
http://i17.ebayimg.com/01/i/03/77/b3/9f_1_b.JPG
but this kit is for 2000 i have the 1000
so can some please tell me how i can make this all work with my stock head unit on the TC
the poeple are bein _____ about the installation prince over $100$ to install
so if i need additional parts please tell me and tell me the instrustions please!! [/img]
Old Nov 17, 2005 | 01:01 PM
JINeration's Avatar
bump come on guys
Old Nov 17, 2005 | 01:19 PM
2azfe's Avatar
did u try looking the ICE section? anyway, if you are goint to use your stock HU, you will need a line-out converter if your amp does not have any high level inputs... to rune the power wires for te amp, what i did was i ran the wires through a rubber grommet on the driver side just beside the steering column.. i was able to fit in a guage 4wire through... then its up o you how you want to run the wire going to your amp depending on where you want to mount it...
Old Nov 17, 2005 | 01:21 PM
JINeration's Avatar
i just want to hook it up and put the amp in the back by my box do u have any pictures and wut kind of converter do u have a picture of that?
Old Nov 17, 2005 | 01:30 PM
2azfe's Avatar
i have a picture installed already and not the step by step instrcutions... its not that hard... as long as you now the basics of wiring, your fine,,, running the wires are not difficult...
Old Nov 17, 2005 | 02:35 PM
SCI_TC_GUY's Avatar
http://www.crutchfield.com/S-bfOhApw...&display=L#Tab
that's what you need to get sound from your HU to the amp... You're also going to need to run a 4ga. power wire from your battery to the amplifier with a fuse in it (within 18in. of the battery connection) Use an 80 amp fuse...
You'll also need to find a wire that only has power when the car is on....this will be your remote wire and you'll have to run it to the amp...
You'll need a 4ga. ground wire that goes from the amp to the Chassis of the car....
If you get this far, put up a message on here and I"ll help you out the rest of the way.....if you're too intimidated, take it to a stereo shop (NOT BEST BUY OR CIRCUT CITY)
Old Nov 18, 2005 | 03:00 AM
JINeration's Avatar
woohoo my friend helped me install it today and it sounds awesome!!! thanks for the feedback guys
SuBSiN
Mar 13, 2015 04:02 AM
randomsuper
Feb 27, 2015 01:29 AM
Frustratez
Feb 26, 2015 04:03 PM
ofgarcia
Dec 22, 2014 12:27 AM
TheRedBox
31
Dec 2, 2003 04:53 PM
