need installation
i need help installin my 2 subs and amp onto my TC
i have a box but i dont have amps how do i install my 2 12"s onto my box they said i needed a special type of sealent to make it good but wut kind and do i just screw it in
how do i jus hook everything up these are the thing i have
http://i22.ebayimg.com/03/i/05/78/e2/36_1.JPG
that would b the amp
then i have these 2 subs
http://i18.ebayimg.com/02/i/05/54/11/cf_1.JPG
and a box of course but with out the amps inside so i need to know how to put them in
http://i17.ebayimg.com/01/i/03/77/b3/9f_1_b.JPG
but this kit is for 2000 i have the 1000
so can some please tell me how i can make this all work with my stock head unit on the TC
the poeple are bein _____ about the installation prince over $100$ to install
so if i need additional parts please tell me and tell me the instrustions please!!
[/img]
did u try looking the ICE section? anyway, if you are goint to use your stock HU, you will need a line-out converter if your amp does not have any high level inputs... to rune the power wires for te amp, what i did was i ran the wires through a rubber grommet on the driver side just beside the steering column.. i was able to fit in a guage 4wire through... then its up o you how you want to run the wire going to your amp depending on where you want to mount it...
http://www.crutchfield.com/S-bfOhApw...&display=L#Tab
that's what you need to get sound from your HU to the amp... You're also going to need to run a 4ga. power wire from your battery to the amplifier with a fuse in it (within 18in. of the battery connection) Use an 80 amp fuse...
You'll also need to find a wire that only has power when the car is on....this will be your remote wire and you'll have to run it to the amp...
You'll need a 4ga. ground wire that goes from the amp to the Chassis of the car....
If you get this far, put up a message on here and I"ll help you out the rest of the way.....if you're too intimidated, take it to a stereo shop (NOT BEST BUY OR CIRCUT CITY)
TheRedBox
31
Dec 2, 2003 04:53 PM
