One headlight stopped working - anyone else had this?
Old Nov 17, 2005 | 03:32 PM
gavmitchau's Avatar
Default One headlight stopped working - anyone else had this?
Hey I noticed yesterday that one of my headlights stopped working.. I tried the bulb out of it in the other side and it worked fine... seems its something else? Anyone else seen/had this happen..
Old Nov 17, 2005 | 03:37 PM
krdshrk's Avatar
Probably a wiring problem. Take it to the dealer for them to fix.
Old Nov 17, 2005 | 03:38 PM
SSM_tC's Avatar
Are you using aftermarket Bulbs?
if so, check your headlight harness (the wire that the bulb clips onto) and see if it's burnt.
I haven't checked our fuse diagram, so I don't know if eash headlight uses a seperate fuse. You might want to check that as well.
Just guessing
Old Nov 17, 2005 | 03:46 PM
INSIDEOUT's Avatar
I know on the xb eack headlight is on its own fuse you probably blew it out
gavmitchau's Avatar
The connections seemed fine...
Do Aftermarket bulbs cause this?
Old Nov 17, 2005 | 03:59 PM
KINGxOFxSKA's Avatar
Unique Scionikz
sometimes yes if your running a higher wattage bulb than the stock harnesses can handle.
Old Nov 17, 2005 | 04:04 PM
gavmitchau's Avatar
Luminics?
I thought these were 'approved for the TC'
otherwise ALOT of other S/L members I guess *may* be having issueS?
Old Nov 17, 2005 | 04:39 PM
mill0048's Avatar
Many members have had this issue. One of the Luminics retailers sells a beefier harness for the TC to use with their bulbs for $6 each I think.
https://www.scionlife.com/forums/viewtopic.php?t=78296
Old Nov 17, 2005 | 07:44 PM
Emo's Avatar
Emo
I haven't checked our fuse diagram, so I don't know if eash headlight uses a separate fuse. You might want to check that as well.
Just guessing
Wow.. it's like you just described my situation...
1 week ago I turn on my luminics and BAM... one of them was out just like the original poster of the thread...
I took out the bulb and exactly the same thing you told was happening.. inside the wire harness, one of the metal pins was black...
I took it to the dealer (with my stock headlights of course lol ) and they told me they'll order a new one..
but yeah..
I guess Luminics + 6 months of usage = bad news for your harness
-Emo
Old Nov 17, 2005 | 08:02 PM
gavmitchau's Avatar
EXACTLY MY SCENARIO.
including the dealer switch-out ;)
scsteven
Jan 25, 2015 01:06 AM
VCUBoy714
Scion tC 1G ICE & Interior
Jan 5, 2015 08:46 PM
cid_mcdp
Jan 5, 2015 02:45 PM
TheTripleC
Jan 4, 2015 06:46 PM
LeChuck
Dec 9, 2014 02:26 AM
