General Tech and DIY Info for Any Scion
Seat Belt Warning (Disable Beeping)
Old Nov 23, 2005 | 03:52 PM
Joseph_Scion's Avatar
Default Seat Belt Warning (Disable Beeping)
I'm sure that some of you are annoyed with the seatbelt BEEP. If so this is for you.
This will work for all Scion / Toyota.
It can be turned off.
1.) Power on (ignition on will do)
2.) Set trip/ODO to ODO (if its already on ODO you will have to cycle through)
3.) Power off
4.) Power on w/brake on
5.) (Within 6 seconds), press and hold the ODO for 10 seconds or more
6.) While STILL holding the ODO *after 10 seconds*, buckle BOTH seatbelts. Now release the ODO
7.) You will see in the trip display either a "b on" or "b off"
8.) Press the ODO to toggle between "b on" or b off" YOU WANT "b off"
9.) Now power off.
If battery is disconnected, you may lose your setting. Default is always "b on"
Old Nov 23, 2005 | 04:05 PM
aarontrini85's Avatar
hahaha sounds like joke but even if it does work i cant see how it would be usefull lol and at any rate how i drive i think i need an extre seat belt for each passanger
Old Nov 23, 2005 | 04:07 PM
schwettynuts's Avatar
It is not a joke. They always make you do stupid stuff like that. Usually it is not that complicated though lol.
Old Nov 23, 2005 | 04:08 PM
peteyd's Avatar
this was coverd somehwhere else already if you do a serach you can find it also how to change the txt on your stero as well and to reset your windows and moon roof.
Old Nov 23, 2005 | 04:20 PM
mikochu's Avatar
Neat. I added this to the Tech Section. I'll move it to the FAQ forum in a week or so. Thanks to stick_1NZ for the heads-up!
Old Nov 23, 2005 | 04:24 PM
peteyd's Avatar
HAPPY BIRTHDAY MIKOCHU!!!!
Old Nov 23, 2005 | 05:25 PM
yokillr's Avatar
OR YOU COULD JUST BUCKLE IT!
Old Nov 23, 2005 | 05:41 PM
true....
Old Nov 23, 2005 | 05:50 PM
Kenshin's Avatar
Ive dont this to my tC, its annoying, and to those saying "OMG BBQ WHY DONT YOU JUST BUCKLE UP LOL OK?? HAR HAR". Usually when I am driving slow through the bank drive through that thing is annoying, or when Im gonna park my car. We all know we should wear our seat belts, but not all of us enjoy hearing the BEEP BEEP BEEP x10000.
Old Nov 23, 2005 | 06:03 PM
mandos's Avatar
This has been posted many a time...I turned mine off long ago
Old Nov 23, 2005 | 06:12 PM
ycart1201's Avatar
nice! i'll be doing it this weekend. driving 2 houses from the mail to my garage with a beep is annoying. (who walks when they can drive). lol
Nathan
ycart1201
Old Nov 23, 2005 | 06:30 PM
yokillr's Avatar
Walk into the bank, and when you park your car, turn it off then take off your seat belt. Now your set. YEA!
And correct me if I'm wrong, but it only beeps when the car is moving?
Old Nov 23, 2005 | 06:47 PM
JW2's Avatar
JW2
up up down down left right a b a b a start select
Old Nov 23, 2005 | 06:49 PM
yokillr's Avatar
Contra?
Old Nov 23, 2005 | 06:50 PM
surfcity40's Avatar
it's already in icdedpple's stickied FAQ, as is virtually every other question one might ask about the tC. new people can CLICK HERE to read the most underutilized FAQ on the boards.
Kenshin's Avatar
LMAO!
And yes it only beeps when its moving, I believe over a couple of MPH, still annoying none the less.
Old Nov 23, 2005 | 06:56 PM
mikochu's Avatar
it's already in icdedpple's stickied FAQ.
the more, the better
Old Nov 23, 2005 | 07:01 PM
speddlysmitt's Avatar
Try moving a turkey and the seatbelt beep keeps on going off.
Old Nov 23, 2005 | 07:02 PM
surfcity40's Avatar
you're right, but sometimes i get unduly frustrated with the same questions over and over when the FAQ is so readily available. it describes all of the easter egg type things, i.e., turning off the seat belt warning, turning off the maintenance light, changing the deck settings, what bulbs are where, yada, yada. i'd think everyone would have it in their bookmarks.
Old Nov 24, 2005 | 01:36 PM
jwaggz82's Avatar
sometimes when i park my car i take it off a second before the car stops rolling --- i had no choice but to disable this ugly sound. .... the above steps work great ...only step i forgot was to plug the belt in at the end (which made me ____ed off cause i tried doing it like 20times before i gave up and went back inside to re-read the directions)
