tC Prep and Build Components for Turbo - What's needed
Old Nov 23, 2005 | 08:52 PM
ScionDad's Avatar
Default tC Prep and Build Components for Turbo - What's needed
Well, j2m2l3 PM'ed me and asked this question that along with myself, I'm sure others may have had been getting. He suggested starting a thread about the Stage 1 turbo and what components are needed for getting the tC ready for any kind of boost...
From the kits - IMO, a few things are a bare minimum and need to be done before the kit shows up. If you have any engine bay mods, let the supplier know this when you order. Not all aftermarket pieces play nice together.
First thing is....read over the instructions before the kit even shows up if you can and note the misc. parts needed. If there is any questions...ask. If it looks Greek to you, hire someone else to do it.
Second, make sure you allow 2 days for comfort of install. When your kit shows up...check each item and make sure it's there and good shape. Start on a Saturday morning knowing the parts store is open the next few days. If you get in a hurry...your hosed.
Third, make sure you have the proper tools to do what you read. I can say the snap ring pliers better be a good "large" set. For Pete sake..use jack stands if using a floor jack.
Fourth, have someone to help. If they know more than you...great. If not, understand you are the brains. If this makes you uncomfortable....hire someone else to do it.
Fifth, Do not short cut things. Plan ahead every step of the process. If you know your doing this, install a boost gauge a few weeks before. Don't pile everything up at once. To much to troubleshoot.
Make a check list as you go. When you're done....check everything again. Leaving some of these things undone can make you go buy another engine block.
This is a list of what will probably benefit before and after installation.
A boost gauge is a must before installation.
Start running Premium gas a few tanks before hand.
Change oil to Full Synthetic at time of install
Change spark plugs to one step colder
Toyota gasket maker (grey) for oil pan and fittings
Vacuum "T"s (Vacuum leaks have to be none)
If you are changing exhaust gaskets - get one
If you are changing downpipe donut gasket..get one
If you are coating your manifold and pipe..allow 2 to 3 weeks for this.
On ZPI kit's, make sure you put the downpipe donut gasket AROUND the turbo down pipe. This will require you to hone out the donut a little...but it will fit.
IMO, these are also ideal, but maybe not necessary.
Wideband AFR gauge
EGT Gauge
Oil Pressure Gauge
Manifold coating for heat
Vacuum distribution block
e-Manage harness instead of cutting wires
Clutch Upgrade (manual)
E.S.K Upgrade (Auto - not verified yet)
Please add items as everyone sees fit. I just threw this out for one thread.
__________________
Old Nov 23, 2005 | 11:26 PM
peteyd's Avatar
and the turbo pops does it once again
Old Nov 24, 2005 | 12:20 AM
ZPIracing's Avatar
get a job.....you have way to much time on your hands
Old Nov 24, 2005 | 12:34 AM
DynomyteSW's Avatar
^^hahaha
good info tho sciondad
Old Nov 24, 2005 | 06:43 AM
bubblemyster's Avatar
lol.
Old Nov 24, 2005 | 01:12 PM
ScionDad's Avatar
Old Nov 26, 2005 | 04:22 AM
retrodrive's Avatar
In the instructions it says to remove the center cartridge by removing some 10mm nut and bolt. What do I unscrew to slide out the cartridge? Basically how do I get to second pin?
Old Nov 26, 2005 | 04:30 AM
jlaznlover's Avatar
Good job sciondad
Also, for the guys that want to know more about boosting a car. here is a good site. it covers a lot of the basic stuff and is pretty extensive. although some of the info is about boosting a Integra, the general info will be helpful to those who would like to know more about turbos.
http://www.beesandgoats.com/boostfaq...html#Wastegate
__________________
Old Nov 26, 2005 | 05:30 AM
danman04x's Avatar
very good info
Old Nov 26, 2005 | 09:48 AM
j2m2l3's Avatar
Nice link. It mentions that lightened flywheel's might not be good for turbo applications.
The link isn't about tC's or even Toyotas so how do u think a lightened flywheel like a Fidanza would act with our turbo'ed cars?
____
NYcarbonTC
Apr 15, 2011 08:11 PM
bruceg
29
Jul 3, 2007 11:46 PM
jaxtcracer
26
Jun 25, 2007 12:55 AM
scion06_tc
Aug 7, 2006 11:30 PM
unseen
152
Apr 21, 2006 01:18 PM
