'06 xA Fog Light Install?
Old Dec 11, 2005 | 12:21 AM
erick's Avatar
Default '06 xA Fog Light Install?
Just purchased OEM fog light for my '06 xA. Has anyone done the install themselves? If so, how difficult is it? I hear the '06's are prewired.
To get the "blanks" out, what do you have to remove to punch them out?
Any help is appreciated.....
______
Old Dec 12, 2005 | 02:21 AM
Duker's Avatar
they just push out on mine
Old Dec 13, 2005 | 01:28 AM
ohcanada_00's Avatar
moving to electrical
Old Dec 13, 2005 | 04:49 PM
06XA's Avatar
The install is very easy. It took me about an hour total. Just follow the included directions step by step.
Just for anyone's info:
--For '06 fogs the bulb was changed from 9006 to H11.
--H11's are 55w bulbs designed for use in low beam headlights. (replacing 9006's)
--H9's are new bulbs designed for use in high beam headlights. They are 65w. The two have different base keyways that are supposed to eliminate the interchanging of the two. They were designed too close in design and they can be easily interchanged. That means that H11er's can use H9's in their place and run a safe higher wattage bulb.
--Silverstar's are yet to be made in either the H9 or H11 style.
Old Dec 14, 2005 | 12:54 AM
erick's Avatar
Thanks for the info and support. I found directions that assume come with my OEM kit. They look pretty straight forward.
Old Dec 17, 2005 | 06:33 PM
xa-minister's Avatar
i thought you were moving it to electrical...lol
Old Dec 22, 2005 | 08:34 PM
erick's Avatar
Default 2006 xa foglight install "redux"
Did the foglight install today.
Some comments and observations - I was concerned about the wiring part of this job. Turned out to be the easiest part.
The difficult part for me was installing the lights in the holes once you punch out the "dummy." The screws are fairly difficult to get to. Once you reassemble the plastic that protects the engine as the instructions indicate, the is no easy way to adjust the lights. Overall, the install took me about 2.5 hours. I am fairly mechanically inclined but certainly not a professional. I found the directions helpful at times but the drawings are difficult to discern at best- especially when trying to figure out the routing of the wiring.
Old Jan 3, 2006 | 04:57 AM
06SCIONXA's Avatar
so do the 06 Scions come prewired for foglights?
_______
Old Jan 3, 2006 | 06:17 AM
jct's Avatar
jct
its about 98% of its prewired
the kit comes with the last wiring harness for the foglights and a relay and the foglight switch
Old Jan 3, 2006 | 04:02 PM
06SCIONXA's Avatar
oh ok well i might order me a set too. thanks for the info.
Old Jan 9, 2006 | 10:35 PM
Macster's Avatar
Anybody got a pic of the foglights on the 06? May pick a set up since i'm at the dealership.
Old Jan 16, 2006 | 07:15 AM
Duker's Avatar
Any deals on the Xa fog light kit, if there isnt anyway to "roll my Own"?
Old Jan 20, 2006 | 04:57 PM
Waitech's Avatar
Erick, Can you please take me where u purchase the fog lights??? Which site that is?
Old Jan 20, 2006 | 06:07 PM
probably www.trdsparks.com
Old Jan 23, 2006 | 05:27 PM
Waitech's Avatar
Now one last questions. I was looking at the instructions of how to install the foglights in trdsparks with pdf format. It doesnt show how to get the wiring into the interior side of the car where u connect the on/off switch. I was looking under the hood and found no passage to stick those wires in
Has anyone install the fog lights themselves and know bout it. any input is appreicated. thanks!!!!
Old Jan 23, 2006 | 06:42 PM
jct's Avatar
jct
the wiring is already there for the interior the plug is taped onto the wiring harness on by the steering shaft
you can see it on page 5 on the trdsparks pdf format
Old Jan 23, 2006 | 06:51 PM
jct's Avatar
jct
errr its on page 6 for the '06 M.Y. page 5 for the '05 M.Y.
Number2
Scion tC 1G Aero & Exterior
Dec 29, 2008 12:59 AM
ITSAXA
Scion xA Aero & Exterior
48
Mar 14, 2006 02:36 PM
bettyhui
Mar 31, 2005 02:37 PM
styleWagon
Aug 12, 2004 06:51 AM
diamond31
Feb 3, 2004 03:17 AM
