exhaust tip question..
Old Dec 12, 2005 | 04:01 PM
DeadRinger's Avatar
Default exhaust tip question..
I tried the search, but came up empty handed. I am not looking to sink a lot of money into the xb, but I cant stand the stock exhaust tip, so I want to add just a tip the fill up that hole. I noticed that there seems to be an oval tip already covering the dinky round one. I am wondering if this oval tip can just be pulled off so I can add a bigger tip, since all the aftermarket tips should fit over the round one. But I wanted to know how hard it is to pull that other peice off (before I "f" it up).. thanks
Old Dec 12, 2005 | 07:44 PM
TXboxdriver's Avatar
yes, you can yank it right off
Old Dec 12, 2005 | 07:48 PM
THE_DON's Avatar
Well, it comes off, but takes some elbow grease...
I went to a muffler shop and just had them cut and weld on a new chrome tip. $40
-THE DON
Old Dec 12, 2005 | 08:15 PM
sorry, mine was easy
but i go to the gym twice a week
so there might be some difference in my version of "easy"
the tip is attached with metal tabs that can be bent back
with that done the tip simply slides off
Old Dec 15, 2005 | 02:54 AM
mile_hi_sci's Avatar
took me minutes and a long flat-head screwdriver to break the little tabs away from the pipe, very easy!!!!!
Old Dec 27, 2005 | 11:13 PM
PartyBoXB's Avatar
I agree there are two tabs just pry them off the pipe and off you are.
Old Jan 2, 2006 | 02:36 AM
xBHAWK's Avatar
Default ....I disagree....
I too, did not like the look of the stock crome tip. I spent $8 on a big crome oval tip that fills the bumber cut-out much better.
Depending on the level of corrosion, this tip may be fused permanantly. How new is your BOX? If it is fused permanantly, or if you want an easy install, do not even bother removing the stock crome exhaust tip, just mount the new tip over the stock tip. Use wormgear clamp to secure it because vibrations will loosen the mounting screws provided.
See this thread and view photos. See if you like it crome and easy as I do.
https://www.scionlife.com/forums/vie...299&highlight=
toyotaisme
Jan 10, 2015 10:24 PM
PTUNING
Dec 11, 2014 08:09 PM
PTUNING
Dec 6, 2014 03:58 PM
mrlaypo
11
Dec 6, 2003 01:51 AM
LiquidSilver
Oct 29, 2003 03:35 PM
