I need some help from the box building guru's...
Old Dec 17, 2005 | 01:08 PM
Smoses799's Avatar
Default I need some help from the box building guru's...
Okie, here is the project. I need a box designed for 2 crossfire xt215. Right now, i have one in the old box that my 16.O was in. Here are the requirements.
1. can be sealed or ported. (prolly sealed due to size restriction)
2. needs to fit in the back of the tc w/ the rear seat up. (perferably, w/ 2 inch so it can relcine)
other then that, you have free domain.
here is a link to the tech info on the sub. ill list some of it below, but the link has much more and a few suggested box spec's (that wont work with a tc app)
http://www.crossfirecaraudio.com/ima.../BMF/XT215.pdf
S p e c i f i c a t i o n s
Driver Description 15" subwoofer, dvc
Mounting Depth (in/mm) 8.4375/214
Cutout Diameter (in/mm) 14.125/359
Woofer Outer Diameter (in/mm) 15.375/391
Woofer Displacement (cu.ft./ltr) .192/5.44
Impedance Dual 1.8 ohm
Nominal Power Handling (RMS) 1500 watts
Maximum Power Handling (PE) 2500 watts
Dynamic Power Handling 4000 watts
Voice Coil Size 3" 4-layer all aluminum
Magnet Weight 240 oz.
Frequency Response 22-250Hz
Resonant Frequency (fs) 22.8Hz
Qts .322
Qms 4.068
Qes .350
VAS (cu. ft./ltr) 4.31/122.05
Efficiency (2.83V/1M) 88.6 dB
thus far, noone can figure out how to do it. Ive asked my friends, ed, my co-workers, carpenters, my performance shop, drunk mall santas, and 3 clowns (thought they might have some insight due to the clown car trick).. now im askin the peeps here... this cant be impossible.
Old Dec 17, 2005 | 01:20 PM
Smoses799's Avatar
42 wide 28 deep and 12 high are the max demensions of the trunk if i remembered correctly in the tc's trunk, so the box design is probably need to be creative
Old Dec 17, 2005 | 06:34 PM
-Keith-'s Avatar
do u want to keep the spare tire well?... What about custom fiberglass job..?
Old Dec 18, 2005 | 12:31 PM
Smoses799's Avatar
id like to keep the spare tire, but im willing to give the space up.
Id rather stay away from fiberglass for 2 reasons. 1) ive never heard one that sounded very good. 2) i dont know if id want to toss 3k rms into a fiberglass box.
Old Dec 18, 2005 | 03:42 PM
WeDriveScions's Avatar
Wow... TWO 15's? Yikes.
I run two lil' 8's with deadoning and max out the tolerances in ears at 3/4 volume.
Here's my design, Which I run my 8's with ported, which you'd just have to make much bigger and angle a little different to get to work...
Old Dec 18, 2005 | 06:07 PM
-Keith-'s Avatar
3k into a fiberglass box wtf you smoking...
Not sound good? Guess you havent seen a box built to specs then
Old Dec 18, 2005 | 07:57 PM
retrodrive's Avatar
This is the funniest thing I have heared in a while in car audio. Here is how you can do it. Make the back of a box fiberglass so that it goes inside the rear fender and follows it's contour. That right there will give you a lot of space to play with. The front of the box can be mdf board or fiberglass. The box will have a lot of space and won't stick out too far from the side of the trunk.
Old Dec 19, 2005 | 02:38 PM
mandos's Avatar
Yeah...so...without glassing...it's pretty much impossible to make a box big enough for those space hogs....you really do need to glass the bottom/sides to get more room.
Old Dec 19, 2005 | 07:04 PM
Smoses799's Avatar
well, i guess ill just have to have the bottem and sides glassed then.
Old Dec 19, 2005 | 09:04 PM
retrodrive's Avatar
once you get the quote for fiberglassing something, get back here and post the price. If you are saying that a box would cost you $3k, you are being ripped off. At least we can tell you if you are charged appropriate price for the work you are getting done.
Old Dec 19, 2005 | 09:06 PM
-Keith-'s Avatar
If you want a box built I can build it for you... either have to pay for shipping or come up here and get it...
Old Dec 20, 2005 | 03:30 AM
Smoses799's Avatar
hmm that might work. i have family in vallejo.
Old Dec 20, 2005 | 06:34 PM
-Keith-'s Avatar
let me know
jdlong
May 17, 2018 05:20 PM
midtowndesi
Jul 11, 2015 09:58 PM
Erager09
Apr 23, 2015 01:50 PM
ninja_steph
Feb 5, 2015 02:50 AM
