Question about fog wiring
Old Dec 20, 2005 | 01:07 AM
gcxandy's Avatar
Default Question about fog wiring
So i wired my fogs directly to the headlight lead wire.
Im not running a switch of any sorts. Just the relay , fuse, ground and lead wire.
It has been fine for the last 2 weeks but today the fogs stopped working.
Anyone have any advice on where i should check for problems?
Old Dec 20, 2005 | 07:37 PM
Sam_J84's Avatar
i dunno, check the relay?
Old Dec 20, 2005 | 11:35 PM
JocoJef's Avatar
See if the connection is still good from the headlights....if that is still intact I'd check the grounds and if those are fine....then you need a new relay
Old Dec 21, 2005 | 12:29 AM
Sam_J84's Avatar
does anyone know if wiring the fogs directly to your headlights or sidemarkers is safe?
Old Dec 21, 2005 | 03:28 AM
Jowie's Avatar
You arent going directly to the headlight wiring if you are using a relay the way it was supposed to be used. Using the stock headlight wiring to trigger the relay to switch power onto the fogs should be fine. Relays do not draw much current for their switching operation.
Old Dec 21, 2005 | 03:23 PM
Sam_J84's Avatar
thanks dude, that helps alot.
Old Dec 23, 2005 | 07:05 PM
gcxandy's Avatar
found out it was the fuse. got a new one, i wonder how long this one will last =T
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
NewBox06
Feb 3, 2015 04:02 AM
fliggah
May 28, 2004 07:51 PM
