Leak between CC s-pipe and AW header? (Help Plz)
Old Dec 23, 2005 | 09:48 PM
PT's Avatar
PT
Default Leak between CC s-pipe and AW header? (Help Plz)
Hey,
So I just got everything installed yesterday and I hear somthing leaking. I used the CC S-pipe gasket (that was provided with the CC s-pipe) for the connection between the AW header and S-pipe. I'm not sure if this is the correct gasket to be used. It didn't fit very well with that gasket. Anybody know what I'm suppose to buy?? Thanks I really appreciate it! I want to go buy it today!!! It's so freakin loud.
Old Dec 23, 2005 | 09:51 PM
Munch's Avatar
Default Re: Leak between CC s-pipe and AW header? (Help Plz)
Originally Posted by PT
Hey,
It's because the stock bolts don't thread in far enough. I've seen this before . You can either get some washers and add them to take up the space, or you can buy a set of bolts and nuts and use those to tighten it up. Either way will work.
Old Dec 23, 2005 | 10:01 PM
The_Instigator's Avatar
I did the washer trick and also put some copper gasket sealant on the donut gasket to help get a better seal and it has been great.
Old Dec 23, 2005 | 11:50 PM
PT's Avatar
PT
So what size bolts do I need? Also what is the washer trick I'm still confused. Thanks for the help
Old Dec 23, 2005 | 11:54 PM
Munch's Avatar
Just buy pack of washers that will fit over the factory bolts, but make sure that the holes are not bigger than the factory bolt head. stack like 3 or 4 on each side between the bolt head and the factory springs. Then tighten the bolts into the header. That's it.
Old Dec 24, 2005 | 12:15 AM
PT's Avatar
PT
Ahhhh, So the springs is the problem? They won't allow me to tighten it far enough? Okay thanks for the help!!
Old Dec 24, 2005 | 12:18 AM
PT's Avatar
PT
Just curious how important is it to install the brackets from the stock header?
Old Dec 24, 2005 | 12:19 AM
Munch's Avatar
It's not the springs. The stock bolts are not threaded all the way. That is the problem.
Old Dec 24, 2005 | 12:20 AM
Munch's Avatar
They hold the header in place on the bottom. you can run without them, but I would put at least one side on. I know that they don't really line up with the header. But you can get them to work.
Hydryman
Feb 23, 2016 03:35 PM
CrowJenkins
Oct 9, 2015 10:47 PM
vi3tb0i09
Sep 23, 2015 08:32 PM
Jvg2727
Scion xD Drivetrain & Power
Aug 24, 2015 04:40 AM
