Oil leak question
Old Jul 20, 2015 | 03:03 AM
Jvg2727's Avatar
Default Oil leak question
Hey guys. New to forum so thanks for any help. Recently purchased an automatic 2008 xd. So far I'm loving it. My mechanic did note an engine oil leak. It is currently minor and seems to be coming from the area of a timing chain cover, it doesn't seem to effect oil levels between changes and it doesn't actually leak enough to drip on the drive. My question to the forum is....should I spend the $1000 quoted by Toyota to fix it? I hope the picture helps. This is looking up from under the car. The most yellow area in the top right seems to be the source. Opinions? Thank you!
Old Jul 20, 2015 | 03:47 AM
k1114's Avatar
You were quotes $1k to fix it? What was on the quote? It should have detailed the intended replacement item(s).
Whatever it is, I can't see it being a $1k repair.
Old Jul 20, 2015 | 04:48 PM
Jvg2727's Avatar
I'll have to go back and find the sheet. I cleaned everything off and can feel the rubber gasket sticking out a bit. If I'm not mistaken they said timing chain cover gasket. But I'm just wondering if this should concern me at all considering the small amount of oil being lost.
Old Aug 24, 2015 | 04:40 AM
CXTKRS1's Avatar
Until it starts to drip on the ground I would hold off. Depending on the miles it might be worth replacing the guides, tensioner, and chain while in there.
bootlgr
Jan 26, 2016 01:22 AM
Greg S
May 28, 2015 12:46 AM
Scionxa180
Mar 13, 2015 04:39 AM
TotalChaos
13
Feb 4, 2015 10:24 PM
fearturtle44
15
Feb 13, 2004 01:15 AM
