rpms at 65 mph
Old Dec 26, 2005 | 02:25 AM
asiasi2527's Avatar
Default rpms at 65 mph
at 65 my 2006 xb was turning 3100 in 5th and i think that sounds kind of high i have the stock wheels on it what do yall think about this?
Old Dec 26, 2005 | 03:56 AM
ScionPsyche's Avatar
Is it automatic or stick?
Old Dec 26, 2005 | 03:58 AM
Chimmy3's Avatar
that's high for auto
Old Dec 26, 2005 | 04:25 AM
Keitaro's Avatar
3100 RPM at 5th gear? I think that's normal for the manual xBs. Auto xBs RPM at 70MPH is consistently at 3K revs.
Old Dec 26, 2005 | 04:30 AM
mavrichie's Avatar
3100 RPM at 65 sounds about right for a 5 speed.
Old Dec 26, 2005 | 06:11 PM
asiasi2527's Avatar
it is a stick and i noticed that the rms dont drop much whe ni shift into fith so i was woundering if there was something wrong with the trans.
Old Dec 26, 2005 | 06:24 PM
chadfo's Avatar
That sounds about normal to me. You should be doing about 4K at 80 mph.
Old Dec 26, 2005 | 08:27 PM
mavrichie's Avatar
Yes 4K at 80 mph with a 5 speed is right on...I am not exactly sure what the RPM is at 65 mph because I live in CA and on the freeways here you are either stopped in traffic or hauling butt when it is clear and 65 is just too slow...
Old Dec 26, 2005 | 09:15 PM
ElChupacabra's Avatar
Mine runs exactly 3k at 60MPH so your 3100RPM at 65MPH sounds right on. I also have a 5sp. 5th is geared really close to 4th so when you shift up to 5th the RPMs dont come down that much. Your tranny seems normal so I wouldnt worry about it at all. The trick here is to see what the RPMs are at 110mph. Let me know if you ever get it to go that fast....
Old Dec 26, 2005 | 11:31 PM
jct's Avatar
jct
around 5k = about 100mph
Old Dec 26, 2005 | 11:58 PM
p2filz's Avatar
its funny how people are asking if it is manuel or auto when u say 5th gear its just funny how little ppl pay attention!
Old Dec 27, 2005 | 12:03 AM
flyerI's Avatar
5spd, 60=3000, 65=3250, 70=3500
auto will be a little less.
If you are far off from this your speedo may be off.
Old Dec 27, 2005 | 12:21 AM
Chimmy3's Avatar
just FYI auto at 3k is about 72-73 MPH give or take (speedometer isn't exactly precise reading)
Old Dec 27, 2005 | 02:53 AM
Tomas's Avatar
Admin Emeritus
Well, here's about the 5th ot 6th time I've posted this little block of infotmation...
Code:
(tire rev per mile) * (final ratio) * (top gear ratio) = (engine RPM at 60MPH)
For the stock xB automatic those numbers are:
880 * 4.15 * 0.70 = 2556.4 RPM
Just using the stock tire size, the differential ratio, and the top gear ratios of
the xB with manual or auto transmission I come out with these figures, plus
or minus maybe 10 RPM...
AUTOMATIC:
2560 RPM @ 60 MPH
2990 RPM @ 70 MPH
MANUAL:
3070 RPM @ 60 MPH
3580 RPM @ 70 MPH
Gear / Ratio     C150 5MT                 U340E 4AT
       1st                3.54:1                         2.84:1
       2nd               1.90:1                         1.55:1
       3rd                1.31:1                         1.00:1
       4th                0.96:1                         0.70:1
       5th                0.81:1                             –
    Reverse           3.25:1                         2.34:1
  Final Drive         4.31:1                         4.15:1
Stock tire revolutions per mile = ~880 (Varies by tire make, size, wear, etc.)
The torque converter is a locking torque converter that locks (no slippage)
while cruising in either 3rd or 4th gear for highway efficiency.
Old Dec 27, 2005 | 05:09 AM
Chimmy3's Avatar
wow
~3600 at 70mph...
no wonder ppl complain about manual FDR
Hey tomas just out of curiousity what would that chart look like for autos with OD off?
Old Dec 27, 2005 | 05:17 AM
Tomas's Avatar
Admin Emeritus
===> An auto with "OD off" is one that cannot shift into 4th gear - in other words it stays in 3rd. <===
(That's ~3650 RPM at 60 MPH...)
BTW, an auto with "OD off" (third gear) and a stick in 4th gear are almost identical RPMs at 60MPH:
Auto (3rd): 3652 RPM
Stick (4th): 3641 RPM
(An auto in 2nd will almost redline at 60... )
Old Dec 27, 2005 | 05:21 AM
TheScionicMan's Avatar
At just over 80, my Box's preferred cruising speed, I'm turning just about 3250. To hit 4K, I'm pushing a solid 90+.
Dropping the O/D at freeway speeds brings the rpms up about 1500.
Old Dec 27, 2005 | 04:09 PM
Right you are - I wasn't paying attention. It would be nice to have a 5 speed automatic like my wife's Accord - it seems like it is always in the perfect gear. You misspelled manual, by the way.
Old Dec 27, 2005 | 04:27 PM
p2filz's Avatar
see were all getting better i put the "manuel" there to see if anyone noticed... j/k i get them confused, btw a 5 speed auto and a 6 speed manual would really be the way to go... not like this is the first time this is stated well any way still good for the price its at later guys
Old Dec 28, 2005 | 02:48 AM
rjlatc06xA's Avatar
DelMarVa
I'm at about 3500 RPMs when I'm doing 70mph in my xA.
