xA Rough Ride - Suggestions
Old Dec 31, 2005 | 12:01 AM
tcFTW's Avatar
Default xA Rough Ride - Suggestions
So my wife has an xA and it rides a little rough with the stock suspension. It feels really stiff and as a result driving around the area we live kind of sucks. Anyone notice this and have the suspension redone with something smoother?
Old Dec 31, 2005 | 12:37 AM
Psyco565's Avatar
i hear koni shocks make a big difference, I have some on backorder right now. We'll see... riding on 18's with 225 40's really hurts going all the way to LA and back.
Old Jan 2, 2006 | 04:31 PM
RTon20s's Avatar
Also if you don't have the coin to drop on the Koni option or do not feel the need for adjustable dampening, look into Monroe replacements. Do a search and you can find the part numbers you need. They are significantly less than the Koni units, and everyone on here who has them say they ride much better than stock.
Old Jan 3, 2006 | 02:31 PM
JSosa's Avatar
if you have no need for the adjutability and if its an every day car, that you dont plan on racing ever. Buy monroe you will be VERy ahppy with the better ride quality ive heard nothing but good thing about the monroe. But once again dont race with the monroes they are not designed for that kind of punishment.
Old Jan 3, 2006 | 03:13 PM
THE_DON's Avatar
Do the Monroe shocks work with a lowered car?
-THE DON
Old Jan 3, 2006 | 03:33 PM
RTon20s's Avatar
If all you are doing is adding a set of 2" springs the standard Monroe shock is fine. If you are planning on a significant drop 3"+ or bags use the following Monroe shocks sold through NAPA.
Information courtesy of Spider13:
Item: Shock - Sensa-Trac - Rear
Product Number: NS 5870
Quantity: 2
Price: $29.99
Core Price: $0.00
Total: $59.98
You can use the listed part numbers for the stock replacement and the "drop shock" to cross reference all of your shock options on Monroe's website. You can also use it to order real custom drop shocks from companies who specialize in that sort of thing.
Old Jan 3, 2006 | 03:48 PM
THE_DON's Avatar
60 bucks? That's all? I might just have to toss some of these on the rear to see what happens.
My ride sucked when it was stock, getting dropped on 18s didn't help.
-THE DON
Old Jan 8, 2006 | 02:10 AM
flyerI's Avatar
I had the same problem. What I have done so far is have an auto trim shop add some foam to the seats from front to back with a little in the lumbar area. I also raised the front of the seat by using washers under the front mounts. That alone made a tremendous difference in the comfort level. I just drove 5 hours each way over New Years. Befrore I could not drive more than 30 min without being sore. I think I will probably go with the Monroe shocks also. For $60 you can't go wrong. I would never adjust the Koni's anyway. It sees the Tein H Tech springs will help the ride too and give you about 1 inch lowere stance. I jsut may go for both.
I have looked at every website I can find for the Monroe shocks. Where do you find them? Anyone?
Old Jan 9, 2006 | 04:48 PM
8BALL's Avatar
I got my Monroes from shockwarehouse.com for $30.80 ea. and free shippng. I could feel the difference in the ride, much better. My Tein H-Techs should be here sometime this week.
Old Jan 9, 2006 | 05:23 PM
deliveryguy's Avatar
raised the front of the seat with washers? ok, how much did you raise it? Yeah, after a few hours, my upper back/sholder blade area really starts hurting!!!!! And here I was wondering if it was just me or the seat in the xb? :?
Old Jan 10, 2006 | 11:37 PM
flyerI's Avatar
I will post some pics in a day or two. The seat was raised about 1/2 inch. Maybe a little less. The foam that the trim shop made a really big difference. I had just the driver's seat done at a cost of $125. I am holding off doing the other as I may buy some Corbeau seats a little later. As I said I will get some pics of the washers and the seats.
Has anyone put the Sensa-matics on the xA? Monroe does not list a part #. Is the rear shock for the xB the same? The xB and the Echo show to be the same. Thanks!
Old Jan 14, 2006 | 11:50 PM
DeansBlackBox's Avatar
I've got the monroes and they work with a 2" drop on my box with no problem. My buddys got a xa with monroes with a 1.75" drop and they work fine.
Josho760
Jun 2, 2015 03:31 AM
killahXB2
Mar 27, 2015 10:45 AM
cid_mcdp
Jan 5, 2015 02:45 PM
gularti
Dec 4, 2014 01:21 PM
fr130
19
Dec 21, 2003 04:56 PM
