the ISSUE with TRD SPRINGS has solved yet?
hey guys..
i been read and search about TRD springs for TC..some other members
has problem with passenger side sits about higer?? i not sure is happened
all the ppls install it..i'm about to get trd springs soon..
plz any one has solved this problem plz help
read this....https://www.scionlife.com/forums/vie...ght=trd+spring
thats what i worry about TRD springs
I have no idea where that problem would come from, outside of not installing them correctly... I and MANY others have the TRD setup with no problems whatsoever and I haven't heard anything negatively about them for a long long time.
You shouldn't worry at all....
thanks alll....
tony
there is nothing wrong with trd springs, or any other springs. if your car sits uneven in the rear it is because you installed the shocks incorrectly. the notch/groove at the bottom of your shocks where the spring ends should both be facing inward or outward. if you have one notch facing outward and the other inward it will be uneven. i just fixed this problem a few days ago, i had trd springs and now i have htech, so i thought is was the springs too until i had the same prob w/ both springs. after you install your shocks correctly and put your car down you'll see that its still uneven, it takes about 2 days to even out
[quote="APRONE"]there is nothing wrong with trd springs, or any other springs. if your car sits uneven in the rear it is because you installed the shocks incorrectly. the notch/groove at the bottom of your shocks where the spring ends should both be facing inward or outward. if you have one notch facing outward and the other inward it will be uneven. i just fixed this problem a few days ago, i had trd springs and now i have htech, so i thought is was the springs too until i had the same prob w/ both springs. after you install your shocks correctly and put your car down you'll see that its still uneven, it takes about 2 days to even out[/quote
wow thanks so much..this tip will help me up so much before i install.
DJ_FroZone
25
May 30, 2019 07:17 PM
Scion0814
Scion xB 2nd-Gen Wheel & Tire
Feb 12, 2015 01:41 AM
kleecker
Dec 31, 2014 09:42 AM
minter66
Dec 15, 2014 01:45 PM
