What type of LED do i need for KEY hole ring & auto shif
is the keyhole ring a 74? and whats the led that i need for the auto shifter where the P D R 23 L light up? is that a 74 also?
Originally Posted by ScionDad
You know, that would be a cool little mod. I'll dig into this if no one else has the info.
how do i change the bulb below the auto shifter? i went as far as removing the center console and cup holder, but i cant seem to pull the shifter cover piece (auto) off...its stuck, i dunno. anyone know how to do this?
For the auto shifter all you need to do is remove the center console and the shift ****. Then, on the right hand side of the auto shifter cover, reach under carefully pull to the right, which will allow you to pull the cover up and away to the left with the light wire attached. Getting to the light is just an easy relase of the clear plastic(spreads the light along the various gears, carefull this is really easy to break) and twist and pull the plug out and there ya go. I myself however have had issues with the #74 LED bulb fitting in there. it doesn't quite fit into the plug, so i used a regular blue bulb in there. I would take pics of this process, but i've done it a few too many times and am really risking breaking some of the parts in there. Good Luck!
please post pics when done. i would like to see as well. plus does anyone know what the led color is in the auto dimming mirror. There is like this one greenish one/ turqoise like color one.
Here is a pic of my #74 Green LEDs in the Cubby Hole and Auto Shifter. (Might be kinda hard to tell on the Auto Shifter, but the green is really bright!)
If anyone finds out about the 'key ring' size bulb, definitely tell us here!
Originally Posted by Yanki01
thats effin sweet! what color is the "R" and "L"?
just changed the shifter bulb....i had to basically pry it off from the right side with a screw driver...and just pull until it came off...its a 74 like previously mentioned.
the key ring on the other hand is confusing. i believe its a 74 since its a 74 in most toyota vehicles...but once i took off the steering wheel covers, both top and bottom, i cant seem to find the location of the bulb or where to start looking. any luck yet ScionDad?
airmankevin1
Feb 14, 2018 01:23 PM
