HELP ASAP!!!
Old Jan 7, 2006 | 10:00 PM
Ninja729's Avatar
Default HELP ASAP!!!
INSTALLED RANDODE CATHODE LIGHTS .... but they dont work i cant figure out why. the only thing i left out in the instructions was to unscrew a 6mm screw and screw it back with the cathode light!!!
I NEED HELP REALLY BAD!!!
Old Jan 7, 2006 | 10:15 PM
scioncraze05's Avatar
it needs to be grounded in order for them to work, there is a wire with a ring on it connect it to the 6mm screw
Old Jan 7, 2006 | 10:25 PM
Ninja729's Avatar
ok..... where is the 6mm screw i couldnt figure it out. is that the one that is on the right side of the driver seet foot area?
Old Jan 8, 2006 | 12:14 AM
TCMONKEE's Avatar
If it's connected to the a fuse protector kind of thingy. You might wanna check that. happened to me before.
Old Jan 8, 2006 | 01:16 AM
Mmartin_47's Avatar
When I had mines, I grounded it where the carpet is under the console on the right. You will see a metal bar and a nut right there. You will have to pull the carpet away. Start by pulling out the black button. You should see it.
danielv
Aug 26, 2015 07:14 PM
vancouverray
Scion xB 2nd-Gen Wheel & Tire
Aug 10, 2015 10:20 PM
JLOVE1
Jul 31, 2015 02:40 AM
pdxgen2
Mar 14, 2015 01:56 AM
